Exhaust hanger
Old Oct 9, 2011 | 10:47 AM
LongoTE's Avatar
Exhaust hanger
I figured this was more of a general max question. Do I need a specific exhaust hanger for my car? I have an 03SE and the rubber hanger right after the resonator under the car is stretched and deformed and now the exhaust clunks on the crossmember. I find similar ones at autozone so I can just get those right? I think I found an exhaust diagram which gave a part number of 8287 so just want to double check that anything that's similar is good to go.
And what's the difficulty in changing one? From being under the car it looks like it's just an unbolt and slip off. Ill use some heat to try to prevent bolt breaking if that might help.
Old Oct 9, 2011 | 11:49 AM
DanNY's Avatar
Ad·min·is·tra·tor
i think a generic one should work. the parts store should have one for you. just let them know what it's for and it's slip off and slip on. wd40 helps.
Old Oct 9, 2011 | 12:40 PM
LongoTE's Avatar
Thanks for the adivce.
Old Oct 10, 2011 | 12:13 AM
Mr. Blue Sky's Avatar
could be a little hard if it is stuck on. Using wd40 as mentioned above will help. Also having something to pry at it with(flathead screw driver, or a pry bar) could help
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
TheMafia
Sep 4, 2015 08:26 AM
