1 step colder NGK cooper plugs
Old Jan 3, 2002 | 08:22 PM
1MAX2NV's Avatar
Anyone know what the part number? What about 2 step colder?
Old Jan 3, 2002 | 08:26 PM
Sprint's Avatar
PFR6G-11
PFR7G-11
all platinum
Old Jan 3, 2002 | 08:30 PM
1MAX2NV's Avatar
How about just regular cooper ones?
Anyone know the part number for cooper ones?
Old Jan 3, 2002 | 08:34 PM
Sprint's Avatar
opps sorry.. i just re-read the post..
BKR6E
BKR7E
Old Jan 3, 2002 | 08:37 PM
Sprint's Avatar
this is what matt uses
BKR7-11
http://forums.maxima.org/showthread....ighlight=BKR6E
Old Jan 3, 2002 | 08:58 PM
1MAX2NV's Avatar
I found this
http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
B stands for 14mm thread diameter
K stands for Hex size 5/8" Projected tip
R stands for resistor
7 is the heat range
E is the V-Groove Tip.
11 is 1.1 mm gap or (.044")
NGK suggest .004" decrease in gap for every +50hp. Stock gap is .044". I guess the 10 (.040") or the 9 (.036")
I guess BKR7E-9 is what I need.
Old Jan 3, 2002 | 08:59 PM
Sprint's Avatar
Re: I found this
7 is the heat range
11 is 1.1 mm
NGK suggest .004" decrease in gap for every 50hp. Stock gap is .044". I guess the 10 (.040") or the 9 (.036")
I BKR7E-9 is what I need.
get the 11 and gap them yourself
Old Jan 3, 2002 | 09:20 PM
1MAX2NV's Avatar
Got bored and looked for some alternatives.
Autolite #3924 is the stock heat range cooper plug.
Autolite #3923 is 1 step colder
Autolite #3922 is 2 steps colder
Old Jan 3, 2002 | 09:32 PM
max'n out's Avatar
2 step colder you want ngk: bkr7e
It's what I got
Old Jan 4, 2002 | 07:43 AM
MardiGrasMax's Avatar
BKR7 is gapped at .035
BKR7E-11 is gapped at .043
Tony, Since you run NA most of the time I would recomend you stay with the one step colder .043 gap. However if you ever try 100hp or more out of the nitrous I would recomend two steps colder .035 gap.
These plugs are cheep enough that you could get a set of two steps for the track and just swap them for track days.
Old Jan 4, 2002 | 07:48 AM
ejj's Avatar
ejj
Any down side to copper plugs? Just shorter life?
Old Jan 4, 2002 | 07:50 AM
No, Yes.
Old Jan 4, 2002 | 07:52 AM
Sprint's Avatar
down side = shorter life
up side = better spark
Old Jan 4, 2002 | 07:59 AM
ejj's Avatar
ejj
Cool, where can you pick these up? Do dealers carry them? Local auto stores?
Thanks guys.
Old Jan 4, 2002 | 08:03 AM
Sprint's Avatar
Thanks guys.
both
Old Aug 26, 2002 | 02:42 PM
jdmmax's Avatar
bringing this tread back from the dead.
so on a Nos kit 5124
which one of the previously mentioned spark plugs are recommened. i will be starting out at a 50 shot but 75-85 shot for street and 100 shot at the track. sould i get 2 sets of spark plugs. one step for street and 2 step for track????//
thanks
jdmmax
Old Aug 26, 2002 | 03:06 PM
hokiemax's Avatar
thanks
jdmmax
Well, i'm gonna get one step colder coppers, gap them to .040, and thats gonna be my setup for the track and street. I have a 70 shot.
Old Aug 26, 2002 | 03:23 PM
matt calder's Avatar
thanks
jdmmax
For a 50 shot you dont need 1 step colder plugs. Just gap them to .042-.043 and you should be alright. that is what I have right now and I am running really good.
anything over 50 and you go to 1 step colder. 100 shot you will prolly need to go to 2 step colder
Old Aug 26, 2002 | 03:25 PM
jdmmax's Avatar
thanks
frank
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
