Quality park plug recommendations please
Old Jan 4, 2002 | 09:57 AM
Supermachoman's Avatar
Quality spark plug recommendations please
I am going to be replacing my spark plugs in the near future. I do not care about price or life of the spark plugs, all I care about is the quality and performance of the plugs. I was leaning towards NGK Iridium IX (part # BKR5EIX-11, I believe), as NGK is recommended in the service manual, but I am open to suggestions. Would someone please recommend a top quality spark plug (cost aside). My Maxima is a 1995, and I don't plan on running NOS, so I would like to stay with the recommended heat range unless someone could tell me otherwise.
Thanks in advance,
Tyler
Old Jan 4, 2002 | 10:02 AM
deezo's Avatar
Stay with the stock NGK's. There is a slight drop in low end power with other plugs. I'm running Bosch +4's and there is a little drop in the low end, other other hand my but dyno says I have more power up top(may just be due to the tune-up).
Sprint's Avatar
Stick with NGK..
Plat, Copper, Iridum.. its all up to you.. Copper better spark.. doesn't last as long.. palgurized{sp} from MardigrasMax
Old Jan 4, 2002 | 10:04 AM
SuDZ's Avatar
Yeah just keep with the ones from the dealer. The cost is a bit more high but the best plug for your engine. You will get around 60 - 70K out of them anyhow so it may be the last ones you buy.
SuDZ
Old Jan 4, 2002 | 10:30 AM
Thanks guys. Am I correct in assuming that the platinum OEM replacement (NGK #PFR5G-11) is the one you would recommend?
Old Jan 4, 2002 | 10:31 AM
Sprint's Avatar
if you are a DIY get the copper and change them 30k .. if you are lazy man.. get the NGK #PFR5G-11
Old Jan 4, 2002 | 10:35 AM
Do you have the part number for the NGK copper plugs? I went to NGK's web site and used the part finder, but couldn't find the part number. Thank you.
Old Jan 4, 2002 | 10:41 AM
Sprint's Avatar
BKR5E-11
05RLS2
Sep 27, 2015 09:24 PM
JoshG
51
Sep 21, 2015 10:41 PM
cruce91
Sep 20, 2015 10:23 AM
jerrod99_se-l
Sep 16, 2015 02:39 AM
sdotcarter
Sep 2, 2015 09:53 PM
