Just Repainted my plastic Valve Cover(or whatever its called)
Old 01-07-2002, 02:31 PM
  #41
deezo's Avatar
Originally posted by Santa
Looks sweet, like how is matches car color, wich i had thought of that when i did mine, i guess i could do it again, but taking off the paint will be a beotch.
You won't really need to take the paint off, just sand it down.
deezo is offline
Old 01-07-2002, 02:35 PM
  #42
Stealth Max's Avatar
Re: Just Repainted my plastic Valve Cover(or whatever its called)
Originally posted by SprintMax
Dana.. is the paint oil based? do you think you could paint a body kit with it?
Stop being a cheap a@@ and get a body shop paint/install the body kit for you the right way!!!! SpriteMax
BTW Dana the valve cover looks good.
Stealth Max is offline
Old 01-07-2002, 02:57 PM
  #43
NYCe MaXiMa's Avatar
that looks REALLY good.
good job
So this paint can withstand heat as well? I like how well it matches factory paint, it would definately be a good alternative for going to a body shop to paint something. I want to get some to paint my mud flaps
NYCe MaXiMa is offline
Old 01-07-2002, 03:55 PM
  #44
Vyrus's Avatar
Klaus...
Like I said its fine for you to be on the forum but do not act like you have a Maxima. Do not bullsh*t or I will bust your *ss.
-Cyrus
Vyrus is offline
Old 01-07-2002, 04:01 PM
  #45
deezo's Avatar
good job
I don't think heat will be a problem at all. Automotive paint should beable to withstand both extremes.
Thanks again fellas.
deezo is offline
Old 01-07-2002, 04:16 PM
  #46
AndyXXL's Avatar
Looks good Dana. Too bad no one sees it unless you drive with the hood open.
AndyXXL is offline
Old 01-07-2002, 04:26 PM
  #47
deezo's Avatar
deezo is offline
Old 01-07-2002, 05:46 PM
  #48
SLC I30t's Avatar
If you use spray paint, just put vaseline on the letters....
then when it dries you just wipe it off.
SLC I30t is offline
tgreen
10-18-2015 06:18 PM
JoshG
51
09-21-2015 10:41 PM
Max139617
09-20-2015 07:25 PM
Max139617
09-20-2015 07:09 PM
tardrex
09-11-2015 07:35 PM
Quick Reply: Just Repainted my plastic Valve Cover(or whatever its called)
