Raced, and check engine light comes on
Old Jan 6, 2002 | 02:53 PM
jsohn's Avatar
I have a 2K2 SE Auto and I was racing last night. Went full throttle a couple of times and noticed some smoke from the hood and it smelled like Auto Tran fluid burning, but went away later. But as I was driving, then as I was driving, the gas pedal didn't work, meaning i could not accelerate. The RPM just stayed at 1000 in drive and All I could do was about 5 MPH. Seems the computer cut off the gas pedal. Then the TCS off, Slip, check engine light is on. In park the idling rpm was 2000, normally it is 900. I pressed the gas, and nothing happens. Then I shut off the car again and let it sit for 5 minutes and start again, then all of the other lights go off, except for Check engine light, but this time A/T check light blinks for about 2 seconds and goes off. Now the car runs fine, except for the check engine light on. Does anyone know what went wrong? Is my transmission messed up or did the computer just go crazy. I will be taking my car into the dealer.
Old Jan 6, 2002 | 02:55 PM
deezo's Avatar
Did you break the car in. I wouldn't be racing until I at least had 1000 miles on the car.
Old Jan 6, 2002 | 03:01 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
stupid limp mode on the new cars. grrrrrrrrrrrrrrrrrrrrrrrrrr
Old Jan 6, 2002 | 03:30 PM
Telus.net
good job son.
Old Jan 6, 2002 | 03:49 PM
jsohn's Avatar
Yeah I broke the car in good. I have 3300 miles right now.
Old Jan 6, 2002 | 03:59 PM
LEADFOOT's Avatar
Check the alternator belt? Could be the smokin' culprit and lead to all sorts of stuff shutting down. Let us know what it is when dealer finds out.
Old Jan 6, 2002 | 05:34 PM
emax02's Avatar
Re: Raced, and check engine light comes on
Congrats, you put your car in limp mode{AKA gimp mode}. On my 6spd max, if I hit the rev limeter it will go into limp mode. My top speed in limp mode was 21MPH going down hill . If your car goes into limp mode again all you need to do is pull off the road, shut the car off, remove the key from the ignition and then start the car back up. If you do that the limp mode will go away.
Now for the smell, it has nothing to do with a lose belt or anything like that. On new car's they often make weird smells when pushed, most likely you burned a little bit of your tranny fluid and thats what caused the odor and smoke.
I found that the only way to get the check engine light off after it has gone into limp mode is to park the car for 24 hours, it worked for me.
Old Jan 6, 2002 | 05:37 PM
Re: Re: Raced, and check engine light comes on
that sucks, i can never not drive my car for that long i need a OBII scanner.
Old Jan 6, 2002 | 06:13 PM
Maxilicious's Avatar
I hate limp mode. Is that when you fill your car with Jack Daniels
Old Jan 6, 2002 | 07:09 PM
LaXor's Avatar
Did you keep bouncing off the rev limiter? Because I have hit it before and nothing happened?
Did my car degimp it self.
Old Jan 6, 2002 | 08:01 PM
jsohn's Avatar
Thanks Emax95 for the info. But when I first pulled over and shut the engine off, it was still in this limp mode. After about 10 minutes it went away. But why did the check A/T light flash? Was there any damage done, or should I not worry?
Old Jan 6, 2002 | 08:07 PM
MaximaRider's Avatar
i doubt one beat down could have hurt your car, maxima's are made to be some what bullitproof. my throttle cable got stuck at WOT on a screw for the upper portion of my PR CAI, it was revving at redline for about 2 minutes because we couldn't figure out what was wrong until we got the car to a safe spot.
Old Jan 6, 2002 | 08:16 PM
jsohn's Avatar
Mr friend wanted to drive the car, so i let him, but I think he was going full throttle in number 3 position of the automatic. Sometimes if one is not used to the 2k2 auto shifter because of the way stick comes down. Maybe thats why the car did this.
Old Jan 6, 2002 | 09:08 PM
NoHalo's Avatar
Stupid Limp Mode... AAAAAaaaaaaarrrrrrrrgh!!!
Should be a simpler way to reset stuff--- Like a Viagra switch or something...
Old Jan 6, 2002 | 09:55 PM
1MAX2NV's Avatar
Take it to the dealer
Get them to pull the code. You had some major system failuare for the car to get into limp mode.
Old Jan 7, 2002 | 01:05 AM
emax02's Avatar
Did you remove the key from the ignition on your first re-start attemp?
As for your A/T light flashing, I do not know what the sensor looks for when it set's off the light for your A/T. Most likely it flashes when it sences a over heating condtion, the only other way it should blink is if your low on fluid.
1max2nv, that is not true, my car has gone into limp mode on two seperate occasions, both times it happened becasue I hit my rev limeter. 2002 max's are more advanced electronicaly then older max's, it is just a protection system that kicks in when the car senses a possible danger. This happens to prevent damage, it does not mean damage has allready been done.
Old Jan 7, 2002 | 04:37 AM
ya and it SUCKS.
Old Jan 7, 2002 | 12:03 PM
95emeraldgxe's Avatar
i heard that the 95 and 96 GXE/GLE/SE dont have rev limiters either - is this true???
Old Jan 7, 2002 | 12:11 PM
Old Jan 7, 2002 | 02:10 PM
SuDZ's Avatar
I would think they would since most cars do as a precaution.
SuDZ
Old Jan 7, 2002 | 02:20 PM
maxed's Avatar
Strange - I've bumped the rev limiter a couple times now in my 02 6spd with no ill effects other than looking like a dork just learning to drive a stick
Old Jan 7, 2002 | 07:02 PM
i think i've bumped mine too. emax must have bumped his good or something.
Old Jan 7, 2002 | 07:09 PM
RussMaxManiac
Man already broke a new max!!
Sounds to me the VQ35DE isn't as strong as the 3.0....alot of people are having issues.
Old Jan 7, 2002 | 07:44 PM
maxed's Avatar
Hey Russ are you jealous
I don't think it was the engine, his friend was racing it in 3rd gear and the a/t probably over heated or the ECU has a safety check to "discourage" that kind of behavior.
What other issues have been popping up? (i.e. with the VQ35DE)
Old Jan 7, 2002 | 08:59 PM
Re: Re: Re: Raced, and check engine light comes on
nothing, the engine just likes to save itself. it goes into safe mode when you do dumb things
Old Jan 7, 2002 | 09:07 PM
Telus.net
Russ. seems like you doesn't like the new Altima and Maxima too much......
Old Jan 7, 2002 | 09:58 PM
emax02's Avatar
Both times I hit the rev limeter I was racing and trying to do a quick 2-3 shift, when I went to shift to 3rd{too notchy} it did not go in and at the same moment I was rejected from going to 3rd I masshed the gas instictively to accelerate, all I got was some good red line action though . Maybe you have to bounce of of the rev limeter more then once for the car to go into gimp mode?
Russ , that's not true and you know it, why did you say that? I have not heard of a single mechanical problem in any 3.5 VQ. Prove me wrong and show me a mechanical issue and I will eat my words.
Old Jan 8, 2002 | 02:29 PM
that's happened to me to a couple times but no limp mode. you have trouble with the 2-3 shift too. i just figured it out. it's TOUGH.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
