Venom 400 Control Module
Old Jan 7, 2002 | 05:54 AM
goteron
I have been looking at the venom 400 control module for my 95 5spd maxima. Can you guys tell me anything about it. Percentage horsepower gains. Negative engine effects. Thanks
Old Jan 7, 2002 | 07:06 AM
tifosiv122's Avatar
Re: Venom 400 Control Module
Go to this site and scroll down:
http://www.techstation.com/maxima/engine.htm
Erik
Old Jan 7, 2002 | 07:35 AM
goteron
Re: Re: Venom 400 Control Module
I just read that. It sounds pretty interesting. Unfortunatly I am one of those people that has to try something. I have heard both sides for this thing, so I guess I will just have to try my luck of the draw. When and If I get one I will put up a review on it. Thanks for the help.
Old Jan 7, 2002 | 08:18 AM
Anachronism's Avatar
Re: Re: Re: Venom 400 Control Module
Sounds like it's probably a waste of money, but if you do get it before and after dynos are great. I have heard the same thing yo_its_ok said, it makes the ECU think your throttle is pushed down further then it is. It would feel like you had a lot more power until you pushed the peddle all the way to the floor and it was the same as 3/4 throtle.
Old Jan 7, 2002 | 08:28 AM
goteron
Re: Re: Re: Re: Venom 400 Control Module
Why would it be like 3/4 throttle when it is floored?
Old Jan 7, 2002 | 08:50 AM
Re: Re: Re: Re: Re: Venom 400 Control Module
When you are at 1/2 throttle venom tells ECU you are at 3/4, when you are at 3/4 venom tells ECU you are at full throttle, after 3/4 throttle there is nothing left. This tricks you into thinking the Venom has added power. This is only what I heard about the venom, and I pulled the numbers out of thin air to give an example. If you do get the Venom it is something to look out for.
Old Jan 7, 2002 | 10:44 AM
goteron
Thanks for the info, I will check into it some more. I think one of my friends is going to get one for his sunfire. I will see how his works out.
Old Jan 7, 2002 | 12:34 PM
goteron
Turbo Quad 4? Andyway I will just let him get that, and then see how it works out. That way I can tell if it worth the money. If not, no big deal, I will go without modding my car at all.
Old Jan 7, 2002 | 01:51 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Sorry brah but you can't stop the reward for your services this time.
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
