Autolock warning....(long)
Old Jan 6, 2002 | 12:33 AM
Chunger's Avatar
My other car is a Hybrid
Me be stupid... but I gotta share...
I have an AUTOLOCK that I use on the brake pedal. I have a 5-speed. Not a good combo. I was aware (and accidentally did a few times) start driving the car with the autolock on. It's possible to start the car and start driving. Most of the time I catch myself and I use the tacky yellow steering wheel cover to remind me to take the lock off the brake pedal.
TODAY... I forgot... I was about to leave the parking lot to the street and... OH ****, no brakes! Pulled hard on the E-Brake... locking them up (screeching!) but made it halfway across the street (was supposed to turn left or right!) after banging my front end into the ground. To top it off. I did this right in front of people standing in line at the movie theater across the street. FREE COMEDY SHOW... Quickly pulled the keys and unlocked the AUTOLOCK while acting cool (as if that were possible).
Lucky there were not any cars coming or one of you lucky bastards would be buying my (virtually) new V2
I'm going to wire up a relay to keep me (or anyone else) from starting the car without having the brake pedal depress... I never want to try that again.
Old Jan 6, 2002 | 01:06 AM
NoHalo's Avatar
Re: Autolock warning....(long)
Live and learn. At least you didn't brake, um uh, I mean break anything!
Old Jan 6, 2002 | 05:43 AM
akrus's Avatar
Won't the Autolock work on the clutch pedal. It would still stop someone from starting the car.
Albert
Old Jan 6, 2002 | 09:03 AM
Washington DC Maxima's Avatar
Put the Autolock on your clutch..
Old Jan 6, 2002 | 09:51 AM
NightRider's Avatar
Yeah, the infomercial says that the Autolock attaches to the brake pedal on automatics and to the clutch on 5-speeds. You're forgiven though. Glad you didn't get hurt!!
Old Jan 6, 2002 | 10:19 AM
Chunger's Avatar
I know it will work on the Clutch but I prefered the brake cuz the pedal location makes it much made it much more difficult to let a thief get under the dash...
I envy the autos in this respect...
No big... nothing a relay won't fix.
Old Jan 6, 2002 | 10:36 AM
1MAX2NV's Avatar
Yep...just run the relay off the rear taillights switch. I seen the switch under my dash. Two wires go into the switch.
Old Jan 6, 2002 | 10:41 AM
Cumalot's Avatar
So, you want to trade tranny then?
Old Jan 6, 2002 | 03:14 PM
Pappa Grande's Avatar
Second Warning about Autolock
Recently my clutch fluid reserve was empty. I filled it and bled the system and it works fine. I can't find any leaks.
Ok now to the point - i think putting my autolock on too tight on the clutch peddle put pressure on and made the clutch master cylinder leak.
I could be wrong but I think this is what happened...
Old Jan 6, 2002 | 03:19 PM
black019's Avatar
Lucky there were not any cars coming or one of you lucky bastards would be buying my (virtually) new V2 [/B]
and I would be buying your rims
Old Jan 6, 2002 | 11:57 PM
Chunger's Avatar
Re: Re: Autolock warning....(long)
Pssst....They aren't real, I just photoshopped them in... but don't tell anyone...
Old Jan 7, 2002 | 10:01 AM
99maxi's Avatar
just get another lock and have one on the brake and one on the clutch.
Old Jan 7, 2002 | 11:48 AM
Albertt's Avatar
I'm a bit confused >>
Wouldn't you kick the Autolock with your right foot on your way in? How do you miss a large red metal rod mounted between your legs?
Old Jan 7, 2002 | 11:58 AM
HondaKiller718's Avatar
I have an auto, no problem with autolock. Can't move out of park without the brake pedal depressed. Works great!
Old Jan 7, 2002 | 12:08 PM
99maxi's Avatar
u can still shift the car before u start it into N without pressing the brake. when the car is in N then u can still start it and put it into D without pressing the brake.
Old Jan 7, 2002 | 02:33 PM
Chunger's Avatar
Re: I'm a bit confused >>
My brother asked me the same thing.... The lock is positioned so high up and close to the knee panel that you can get into the car without kicking it...
Anyways... relay is in so I don't have to worry about it anymore.
MaxLvr21
Oct 17, 2015 12:11 PM
maxima297
Sep 30, 2015 03:32 PM
Marc2theMax
Sep 28, 2015 08:13 AM
