Removing Stillen RSB...Problems
Old Jan 7, 2002 | 06:43 AM
ejj's Avatar
ejj
I attempted to remove the Stillen RSB from my 97 GXE this weekend. The top bolts on all of the clamps came off just fine. However, the bottom bolts seem to be frozen in the clamps. The nuts came off fine, but the bolts would not budge.
Anyone else have this problem?
Old Jan 7, 2002 | 09:11 AM
SuDZ's Avatar
Maybe rust eater or WD-40 would lube it up for you. Spray it a few times and try it again.
SuDZ
Old Jan 7, 2002 | 09:12 AM
ejj's Avatar
ejj
SuDZ
Nope. I drilled through one of them...its like the bolt bonded with the bracket. Its not just the head that's stuck, the entire thing is.
I figure I'll take a torch to them next weekend, but it was bugging the hell out of me this weekend.
Old Jan 7, 2002 | 11:25 AM
emax02's Avatar
Try using a hammer.
Old Jan 7, 2002 | 11:26 AM
ejj's Avatar
ejj
Originally posted by emax95
Try using a hammer.
Did that. Nothing works.
Old Jan 7, 2002 | 12:04 PM
HondaKiller718's Avatar
How about leaving it there, maybe it was not meant to be taken off. It's the car gods doing..
Old Jan 7, 2002 | 01:09 PM
ny96max's Avatar
ill bet anything the bolt bonded with the aluminum bracket.
sounds like you will have to drill out them bolts or cut of the brackets. The guy i bought my Stillen RSB from had to get the bolts cut off too. Took me a full day of drilling and pounding to get the rest of the cut bolts from the brackets. I went out and bought beefier bolts, i belive they were rated #8 2nd strongest out there or something, lol. Plus the holes had to be drilled out for the bigger bolts.
goodluck!
Anthony
Old Jan 7, 2002 | 01:12 PM
ejj's Avatar
ejj
goodluck!
Anthony
Yeah, that sounds just like my problem. I did drill one of them, but it was a real pain in the azz. Guess I'll have to do that with the other three.
Thanks.
Old Jan 7, 2002 | 01:15 PM
RedMax95's Avatar
another good reason to go addco
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
