I need some HELP!!!!
Old Jan 10, 2002 | 06:35 PM
Ra1max's Avatar
Okay, the other day my SES light comes on for the first time. So, I go to get the DTC's. Pull off the little panel to turn the screw and there's nothing there! It's just a hole. WTH! I don't know if the previous owner messed with it or what but there's nothing to turn. Anyway, while I was trying to find the screw, my car made an electrical noise. Came up and saw the light blinking codes!?!? I have no idea how that happened. They were 0509 - front heated oxygen sensor in y-pipe, and 1008 - Evap canister. I installed my Cattman y-pipe three weeks ago so the 0509 is probably no coincidence. You think the sensor went bad all of a sudden or could it be something else. Also, how the heck am I supposed to check the codes regularly without that screw? I don't even know how the codes popped up in the first place. Should I replace that whole unit, which seems expensive as hell? I guess I'll have to reset the ECM by unplugging my battery. Do you think the dealership will fix those things under warranty. I am concerned because of my mods. Any and all help is appreciated. Thanx in adv.
Old Jan 10, 2002 | 06:37 PM
Sprint's Avatar
http://forums.maxima.org/showthread.php?threadid=45274
- The Robot
Old Jan 10, 2002 | 06:39 PM
Sprint's Avatar
The Sensor probably got damaged during removal or replacement during the Y pipe install.. i know.. mine did too.. just head to the dealership.. pick up the O2 sensor you need and fix it yourself.. 5 min job.. make sure you know if its the Front LEFT Heated or Front RIGHT Heated
Old Jan 10, 2002 | 06:51 PM
Ra1max's Avatar
Thanks Sprint
Any suggestions as to why that little screw is missing or what I should do about it?
Old Jan 10, 2002 | 06:53 PM
Sprint's Avatar
Re: Thanks Sprint
someone reset it one too many times and eff'd it up.. if the hole is there .. then thats probably the reason.. you might have to open up the ECU case and see if you can fix it.. other wise.. just dont' worry..
Old Jan 10, 2002 | 06:55 PM
Ra1max's Avatar
Well that sux!
Old Jan 10, 2002 | 06:56 PM
Sprint's Avatar
Well that sux!
or you can pay $150 and get another one
Old Jan 10, 2002 | 06:58 PM
Ra1max's Avatar
I think this is where I begin crying...
Old Jan 10, 2002 | 06:59 PM
gtr_rider's Avatar
192.168.1.1
shush sprite...ur commands are set to ***** again arent they?
Old Jan 10, 2002 | 07:00 PM
Sprint's Avatar
wait a sec.. you got a 99? is their no hole? or is their a hole? for the screw?
Old Jan 10, 2002 | 07:01 PM
Sprint's Avatar
what is this whoring you speak of?
Ra1max's Avatar
There's definately a hole
just no screw.
Old Jan 10, 2002 | 07:04 PM
Sprint's Avatar
Re: There's definately a hole
just no screw.
oh ok.. ithought you had a 5th Gen ECU like CHI99Limited.. yeah.. your **** is f#cked up ...
Old Jan 10, 2002 | 07:10 PM
Telus.net
Re: Re: There's definately a hole
Hey Jamie, uh I mean ____.
Old Jan 10, 2002 | 07:11 PM
Sprint's Avatar
Re: Re: Re: There's definately a hole
Old Jan 10, 2002 | 07:16 PM
Telus.net
Re: Re: Re: Re: There's definately a hole
Comon man, you guy's talking styles are identical! Completely identical! So, what's up with the new name???
Old Jan 10, 2002 | 07:22 PM
Sprint's Avatar
Re: Re: Re: Re: Re: There's definately a hole
wtf?
Old Jan 10, 2002 | 07:24 PM
Telus.net
Honestly???
Old Jan 10, 2002 | 07:32 PM
Supermachoman's Avatar
Re: I need some HELP!!!!
How much were your SSR GT1's?
Old Jan 10, 2002 | 08:00 PM
Ra1max's Avatar
$399 a piece at www.tirerack.com
