ABS Sensor Removal
Old Jan 31, 2013 | 11:34 AM
Will's Avatar
ABS Sensor Removal
Hello guys, how the hell did you guys remove your ABS sensors that have been on the car for like 8-10 years, and looks like they are one-piece bonded to the back? I see the bolt (which is guaranteed to break). Do you just remove the bolt, and then try to position a prybar at various points and hammer the other end of the pry bar?
Or is using a propane torch the only way to separate and replace?
Old Jan 31, 2013 | 04:11 PM
vqmaxman's Avatar
The sensor can be removed with lot's of pb blaster and take a blow torch you will need. The sensor is just seized. you can take it out, but just now that fact that the sensor will brake off and the sensor magnet will stay in the hub and you will have to just heat up the hub and just try to heat it up and take it out quick with the vise grip clean out the housing from debrees.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
