Optima Battery Hold-downs...
Old Jan 13, 2002 | 11:49 PM
Str8Maxin's Avatar
Many different companies make nice after market battery hold downs for Honda's, anyone know of any or have a good idea on an Optima battery hold down for the Max???
Old Jan 14, 2002 | 12:53 AM
Nismo's Avatar
You mean that the optima batts wont work with the stock battery holder? I dont think it would be too hard to manufacture one- just a bar of alluminum with drilled holes.
Old Jan 14, 2002 | 01:24 AM
CalsonicSE's Avatar
You mean the Optima is too small for the OEM battery tie-down, right? What I did was cut out a retangular piece of wood (I painted it black, as well) to fit the bottom of the battery tray, put the Optima on top, and there you go - the Optima will now be raised up a bit & can be securely fastened with the OEM tie-down.
Old Jan 14, 2002 | 01:50 AM
Nismo's Avatar
the optima batt is shorter than normal batts. So if thats the case, why not take off the tie rods (the 2 that screw into the battery tie-down bar) and cut the bottom shorter and rebend it back to a hook and tada- shorter tie down bar.
Old Jan 14, 2002 | 08:28 AM
maximadave's Avatar
detailerdaveb@gmail.com
Optima batteries has 4 mounting screws at the bottom of the battery so you can mount it a different way if the top bar didn't fit on top of the battery. That is how I mounted mine.
Old Jan 14, 2002 | 09:24 AM
klubjunkee's Avatar
Just use some washers, I used like 4 each side and it holds in place.
Old Jan 14, 2002 | 12:27 PM
RedMax95's Avatar
Re: Re: Re: Optima Battery Hold-downs...
uh yeah
Old Jan 14, 2002 | 01:08 PM
redmaxpa007's Avatar
i SeE what you did therE
Originally posted by maximadave
Sounds like someone ****ed in his Wheaties this morning
Old Jan 14, 2002 | 05:10 PM
Str8Maxin's Avatar
Actually, i meant an aftermarket hold-down that looked nice. BTW, wHo the f*ck is RBa?
Old Jan 14, 2002 | 08:33 PM
RedMax95's Avatar
i like how u where kind enough to remove his post
i tried one of the universal honda ones once, it was way too short, took it back, then i painted the stock one
Old Jan 15, 2002 | 04:13 AM
Vyrus's Avatar
Same here, and while I was at it I painted some other stuff too (radiator mounts, valve cover etc). It came out well, I'd take a pic but I'm at work right now so that's not possble .
-Cyrus
Old Jan 15, 2002 | 08:54 AM
MaineI30's Avatar
no
i remember i had to do some funky sheet to get my Yellow Top to fit
Old Jan 15, 2002 | 10:16 AM
maxmizd27's Avatar
Doesn't Optima have their own billet hold-down? I thought I remembered seeing one somewhere?
Old Jan 15, 2002 | 09:19 PM
RedMax95's Avatar
-Cyrus
me too, same day i painted all kinds of stuff, a number of caps were painted as well
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
markevans999
Sep 10, 2015 04:29 PM
