HELP! Knock sensor and vehicle speed sensor
Old Jan 14, 2002 | 04:20 PM
JamesAvery's Avatar
My check engine light came on a few days and I did the diagnostic joint I got from this website and the result was 2 problems: knock sensor and vehicle speed sensor. Now this may have resulted from a high speed meeting with the median at 40 mph bc of a high speed chase a few weeks ago.(long story dont ask) Anyways have any of you had any experience with either of these problems? and if so have they definately needed to be replaced(if so how much) or is it possibly a loose connection mechanically or electronically. I have rounded up a multimeter but I cant really tell what is what. Thanks guys
james
Old Jan 14, 2002 | 04:23 PM
Sprint's Avatar
reset it.. take two asprin..
and call me if it comes back...
http://vbxmaxima.8m.com/ecu.html
-The Robot
Old Jan 14, 2002 | 07:45 PM
JamesAvery's Avatar
bump
Old Jan 14, 2002 | 07:46 PM
Sprint's Avatar
so you don't believe me? hmm.. ok
Old Jan 14, 2002 | 08:50 PM
matt calder's Avatar
listen to spritemax young grasshoppa, he knows everything. It would be very wise to listen to him.
Old Jan 14, 2002 | 09:26 PM
DCmax's Avatar
Ive had my ECU trip the Knock Sensor and I reset it and it's never come back. The Knock Sensor doesnt affect the driveability of the car but I have no idea what's up with the speed sensor. The only time Ive seen that trip is after when some people disable their speed limiter.
Old Jan 15, 2002 | 04:57 AM
Washington DC Maxima's Avatar
According to the FSM
there was some kinda surge or somethin that trips that MIL.. I just read it last week.
Old Jan 15, 2002 | 06:02 AM
iwannabmw's Avatar
The only time I ever get a knock sensor code is at the track, and only after running hard for a while. I just reset it and doesn't come back until the next track session. Follow what Sprint said (I think this is three replies that way) and reset thing and see if it comes back. If it does, repost and we'll try to figure it out, but I'm betting it won't.
Old Jan 16, 2002 | 11:36 AM
JamesAvery's Avatar
Allright, Its not that I didnt believe you, I thought you were kidding.
How does that ecu sensor work, does it periodically run tests to see what is wrong? The fact that I had 2 errors is what is making me wonder. I mean if somehting is DEFINATELY wrong and u reset the ecu, will the check engine light for sure come back on?
Old Jan 16, 2002 | 11:41 AM
Jeff92se's Avatar
I'm needing a caw
Just reset the ecu and see if the codes come back. It doesn't cost a dime and it's a cheap diagnostic procedure. What could it hurt? If it comes back, you are still in the same situation.
Note: at least for the 3-gens, this is true. the ecu will keep the code in memory. If it sees 50 turns of the ignition key w/o seeing the code again, it will erase it from memory. If it sees it again, of course the light will stay on.
Eric L.'s Avatar
The Maxima ECU uses two trip detection logic. If a problem is detected on two consecutive trips the check engine light will come back on. So there is no harm resetting the light, because a real problem will turn the light back on again, confirming that there is indeed a problem.
bbsitum
Sep 6, 2019 07:31 PM
I<3 A32's
Sep 10, 2015 11:07 AM
sdotcarter
Sep 2, 2015 09:53 PM
