Things to take care of when car is not driven ..
Old Jan 18, 2002 | 01:54 PM
ksm's Avatar
ksm
What are the things that need to be taken care of when the car is not to be driven for a month or so?
1996 GXE.
Thanks.
Old Jan 18, 2002 | 02:16 PM
Lordrandall's Avatar
A month is not so bad, for long term storage...
click me
Old Jan 18, 2002 | 03:13 PM
theMax's Avatar
storage
ideally you would like to start your car up every 15 days and move it around the block. A month won't hurt it though.
Will it be indoors? If so give it a good washing. You might even put a gas stabilizer in it but most gas is good for 3 months. Also you can let a little air out of the tires. Make sure your cooland and other fluids are at the appropriate level and not leaking.
A month is not that bad at all...
Old Jan 18, 2002 | 03:29 PM
iwannabmw's Avatar
Re: storage
If you have jackstands, and it will be indoors, you can put it up on them. This will prevent flatspots on the tires. You should also disconnect the battery.
Old Jan 18, 2002 | 09:47 PM
Nismo's Avatar
Re: Re: storage
I thought the days of flat spots are over since we no longer use nylon tires.
Old Jan 18, 2002 | 09:54 PM
gtr_rider's Avatar
192.168.1.1
Re: Re: storage
First off: that can leave a hole in your floor board.
Second off: That can leave a hole in your floor.
Neither of these anyone would like to pay to fix.
Old Jan 18, 2002 | 10:09 PM
pocketrocket's Avatar
Re: Re: Re: storage
Yeah ... I thought so too ... or was it steel belted that we'd worry about??? Hmmm ... I ain't a tire expert
Old Jan 18, 2002 | 10:25 PM
click me
If you go long term storage, the oil & filter change is a sure thing to do. Oil builds up contaminants and last thing you want is dirty, acid-rich oil sitting in your engine for months at a time
Old Jan 18, 2002 | 10:42 PM
Max2000's Avatar
Re: storage
what's a gas stablizer?
Old Jan 18, 2002 | 10:46 PM
Re: Re: storage
Additive you can put in your gas tank when you're going to store your car for a while.
Most common brand I've seen is Sta-bil (izzit how you spell it???).
Old Jan 18, 2002 | 10:50 PM
Re: Re: Re: storage
Had a 32 oz. bottle lying around
Sta-bil "keeps fresh fuel fresh for quick starts - prevents fuel deterioration (it won't do wonders on old fuel) - protects engine from gum, varnish, rust & corrosion - no need to drai fuel - contains no alcohol.
They've got a website http://www.goldeagle.com/sta-bil
If you're going to be storing your car for a while (especially during winter), it's good to use a fuel stabilizer. It'll burn off when you drive, no side-effects.
It's NOT an additive like Bardahl Paragon (I love that stuff) or STP stuff. It's not a fuel injector cleaner either. Just keeps your gas fresh.
Old Jan 18, 2002 | 11:15 PM
Max2000's Avatar
Re: Re: Re: Re: storage
got ya.. thanks.. learn something new everyday..
Old Jan 19, 2002 | 07:39 AM
iwannabmw's Avatar
Re: Re: Re: storage
I'm not really sure the full reasoning behind it, but I used to park my car for 2-3 weeks at a time and it used to vibrate for the first few miles. I'm assuming it was until the tires warmed up and the flat spot was gone. Maybe it was something else.
Old Jan 19, 2002 | 07:41 AM
iwannabmw's Avatar
Re: Re: Re: storage
How do you figure There are hardened points for the jack stands. If they are properly placed how are you going to end up with a hole in your floor??
Old Jan 19, 2002 | 10:11 AM
Weasel's Avatar
Wondering this too... I've seen a car left on jackstands for months. As long as your floor isn't styrofoam you should be fine. Think about it... the contact patches for the jackstands is the same or a little bigger than the tires. Pressure equals force over area, and if the area of both is the same the pressure on the floor will be also.
Old Jan 20, 2002 | 01:26 AM
Nismo's Avatar
Re: Re: Re: Re: Re: storage
I think you are talking about the floor as in the ground when he was talking about the floorboars as in the floor of the car. either way, I dont see anything bad with using the jackstands if you have them jacked up on the correct points.
Old Jan 20, 2002 | 06:42 AM
ksm's Avatar
ksm
Thanks everyone. Appreciate your feedback.
Old Jan 20, 2002 | 07:17 PM
theMax's Avatar
Re: Re: Re: Re: Re: Re: storage
where ARE the correct places for jackstands?
Old Jan 21, 2002 | 06:13 AM
iwannabmw's Avatar
Re: Re: Re: Re: Re: Re: Re: storage
On the 4th gen, find the places where you put the spare jack for the front wheels, then look straight in towards the middle of the car. You will see 2 long rectangular beams that start to run down the car lengthwise. For the first few inches of these you will notice it apears to be much thicker here. I place the jackstands here for the front. For the rear, if you feel along the side of the sill towards the inside of the car, you will find a squarish plate that has an oval hole cut into it. I've been placing the jackstands here for the rear. I know the front position is right, but I'm not positive about the rear. Although I have had my car constantly up on the stands using these points and there is/has been no damage whatsoever from using them.
Old Jan 21, 2002 | 09:56 AM
SuDZ's Avatar
I wish I could let my car stay put for a month just to keep the mileage off of it.
SuDZ
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
Balkins
Aug 12, 2015 06:39 AM
