Which transmission cooler to buy?
Old Jan 18, 2002 | 04:22 PM
ptatohed's Avatar
Licensed to Spell
I mostly hear about the Hayden 404 around here but there are many others out there. I surfed the net and found many. I called around at the local auto supply stores and they have a variety as well. So I was wondering, why do you guys go with Hayden? Should I as well? And, if yes, should I get the 404? Why? Is it not overkill?
" Heavy duty driving, Cars, trucks, class "C" motor homes
GVW to 22,000 lbs.
7 1/2" x 15 1/2" x 3/4" "
" Item #1404...Heavy Duty Towing, Pick-Up Trucks with up to 5,000 lbs. at tow. Class "C" motor homes, travel trailers to 24 ft. Gross Vehicle Weight to 22,000 lbs.
Item #1404....$46.00 "
Should I get the 401? 402? 403? Or even the 405?! I spoke to Don at Mobiletek and he was talking about the 404 and possibly the 405. Any advice will be much appreciated.
Thanks guys.
Old Jan 18, 2002 | 08:17 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
http://forums.maxima.org/showthread....threadid=45742
Old Jan 18, 2002 | 08:26 PM
sinewave's Avatar
For the same money, you can get a B&M from Jegs.com. It is much better design. It is a stacked plate design that is more rugged than the fin and tude design of the Hayden. The B&M also has a self-regulating orifice so the fluid can by-pass the cooling fins when the fluid is cold. I've got the #130-70264, rated for 24,000GVW.
Also, they give you enough hose to do the job; with the Hayden you are going to have to buy more.
http://www.jegs.com/cgi-bin/ncommerc...568&prmenbr=76
Old Jan 18, 2002 | 09:38 PM
Lime's Avatar
FAQ! I have the B&M and it's nice.
Old Jan 18, 2002 | 09:57 PM
ptatohed's Avatar
Licensed to Spell
:o)
Thanks guys. Sorry Bill for not checking that first.
sinewave, on the jeg website, it lists the #130-70264's dims as: 11" x 6" x 1.5" and 24,000 GVW but on the .org, it says: 11 x 7.5 x 0.75" and 19,000 GVW. Which is correct.
Thanks lime. Why did you go with B&M?
Thanks again everyone.
Old Jan 18, 2002 | 11:00 PM
MikeO's Avatar
Perma-cool is supposed to be pretty good too
Their design is supposedly better than Tube-fin or stacked plate
http://www.perma-cool.com/Catalog/Cat_page03.html
Old Jan 18, 2002 | 11:26 PM
ptatohed's Avatar
Licensed to Spell
Re: Perma-cool is supposed to be pretty good too
That looks like an oil cooler. That's different, right?
Old Jan 19, 2002 | 06:54 AM
AznStevie's Avatar
i am sorry, but does transmission cooler really needed??? because if it is...i need to get one too
Old Jan 19, 2002 | 07:30 AM
Synki's Avatar
The tranny cooler prolongs the tranny fluid longer.
I am using a Hayens 403x cooler. I think its more then plenty for cooling.
Old Jan 19, 2002 | 08:34 AM
sinewave's Avatar
Re: :o)
They will both work. Since I live in New Orleans (9 months of summer), I opted for the biggest one that I could fit.
Old Jan 19, 2002 | 09:39 AM
bill99gxe's Avatar
Re: :o)
Again, that is clarified through this link which is available in the first one that was given.
http://bmracing.com/noflash/products...perCooler.html
The number on the jegs site is for a larger capacity one, which is usually not recommended, especially in colder climates......this is why sinewave could get a bigger capacity one, since he lives in the Big Easy. For most here, that isn't possible or recommended.
There's no need to re-invent the wheel with these questions as all of them were answered with my simple one line reply and a little .....
Old Jan 19, 2002 | 11:27 AM
sinewave's Avatar
I don't think it would hurt to buy the larger B&M since it has a low temperature bypass.
Old Jan 19, 2002 | 01:16 PM
ptatohed's Avatar
Licensed to Spell
Re: Re: :o)
I got your point the first time and apologised already.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
pears
Sep 18, 2015 05:25 AM
catalinvint
Sep 16, 2015 07:48 PM
