removing and cleaning intake manifold tomorrow...few questions...
first of all my Chilton's manual says to drain the coolant out of the engine...does anyone know how to do this without draining ALL the coolant???
Also..is it really NECESSARY to replace the rubber intake manifold gasket?? I would rather not have to replace it...
finally if anyone has any other tips about the removal and cleaning of the manifold...they would be greatly
appreciated!
Thanks again!
appreciated!
Thanks again!
Re: removing and cleaning intake manifold tomorrow...few questions...
Originally posted by BriGuyMax
appriciated
appriciated
PS get that thing cleaned so your car can get out of its own way again!
finally if anyone has any other tips about the removal and cleaning of the manifold...they would be greatly appriciated!
Thanks again!
Thanks again!
Bruce
Re: Re: removing and cleaning intake manifold tomorrow...few questions...
Originally posted by Nealoc187
Nice spelling genius.
one wrong letter...that's not too bad!
C?d?i]Originally posted by papasmurf [/i]
I really wouldnt imagine considering there really are no fluids that run through that part of the motor but hey its up to you dude if it was me i wouldnt drain them i would just go at.
Bruce [/QUOTE]
that's what I was thinking...
Bruce [/QUOTE]
Re: Re: Re: removing and cleaning intake manifold tomorrow...few questions...
Bruce
Bruce
that's what I was thinking... [/QUOTE]
Yeah exactly i would say just go for it the hell with it if there is fluids i guess well find out huh
Bruce
Haynes doesn't mention draining the coolant at all. Either does the removal writeup at Maxima Driver (Extrude Hone How2). I would probably replace the rubber lower intake manifold gasket unless your car is fairly new. Rubber has a way of deteriorating... Last thing you want is an air leak. I recently picked one up at the dealer for under $4--they even had it in stock. People say you should replace the IAC and the TB gasket but I think those are reuseable. There is also an EGR guide gasket.
Good luck.
Good luck.
lux97Max
Sep 4, 2015 05:42 PM
