Serious Starting Problem....------>
Ive had a weird staring problem for a while now
Every morning when i go to start up my car it stalls out. Now, i just changed my starter a lil less than a month ago so i know its not that causing the problem. It only happens in the early morning when the car has sat for 8-10hrs. But during the day it never happens, only when its ice cold. So what i would do is gas the car right after i turn the key to keep it running that way it wont stall out on me.
Could it be my Optima Deep Cycle Battery causing this?? or maybe a sensor?
Any help or advice is welcome
thanks,
Anthony
Every morning when i go to start up my car it stalls out. Now, i just changed my starter a lil less than a month ago so i know its not that causing the problem. It only happens in the early morning when the car has sat for 8-10hrs. But during the day it never happens, only when its ice cold. So what i would do is gas the car right after i turn the key to keep it running that way it wont stall out on me.Could it be my Optima Deep Cycle Battery causing this?? or maybe a sensor?
thanks,
Anthony
More than likely it's just your fuel system de-pressurizing after sitting overnight; very common. Try turning the key to the "on" position and then waiting 20-30 seconds for the the fuel pump to pressure up before you start the engine.
i had the same shyt on my old maxima. Same exact thing, i used to give it gas as well, never found a fix, wasn't something that bothered me as much as all the other more serious problems.
shilov
Feb 19, 2024 09:40 PM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
