Replacing the sagging wooden floor panel in our trunk ..?
Old Jan 23, 2002 | 08:32 AM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
I'm thinking of getting a sturdier panel from Home Depot and borrow a friend's Dad's wood cutter to custom trim it as a direct replacement. Is wood my only choice or are there better alternative material?
Old Jan 23, 2002 | 08:48 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Replacing the sagging wooden floor panel in our trunk ..?
the cheapest i think is MDF. bevel the edge so it sits in the tub a little..so it doesn't stick up too much and it won't move too much.
Old Jan 23, 2002 | 09:06 AM
theblue's Avatar
wood is too heavy.. you want some thick plastic for your sagging problem
Old Jan 23, 2002 | 09:09 AM
Sprint's Avatar
Old Jan 23, 2002 | 09:10 AM
deezo's Avatar
What about adding strips of wood (1/4 in) to the existing board to make it stronger?
Old Jan 23, 2002 | 09:25 AM
carnal_c30's Avatar
Former Sponsor
underneath where its sagging, you could brace it like deezo said, Im sure that would help... or you could put a stock tire in place of the spare, I think they fit no problem, then the sagging wont be much of a problem would it?
Old Jan 23, 2002 | 09:26 AM
mattattax's Avatar
i think i'm gonna have to go with sprint's idea on this one
Old Jan 23, 2002 | 09:28 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Little known "How-to" courtesy of veteran member Wizeguy:
The stock one was getting crushed. Too much weight I guess.
Here's what I did.
Took a sheet of 1/4" plywood, laid the one from the trunk on to it for a template.
Marked the plywood and cut it out with a jig saw. Drilled out the location for the handle
and then jig sawed that at too.
My original idea was to directly replace the original but to do that you would need to
transfer the clips and foam pieces. Pita.
So what I did was flip the original upside down (foam pieces up) on top of the new piece.
I put wood glue between the pieces. Next I took (12)1/4" bevel headed screws and screwed
from the original cover side into the new plywood piece. Do this with all screws. Next put
weight on it overnight (so the glue can dry).
It now feels pretty solid and should stay in place as the original is still there.
Now to see how long this "Tire Cover Sandwich" lasts.
Old Jan 23, 2002 | 09:29 AM
Sprint's Avatar
that guy owns a white maxima.. well his woman does.. so yeah.. he is smart
Old Jan 23, 2002 | 09:42 AM
max7's Avatar
All white maxima owners are smart
Old Jan 23, 2002 | 09:44 AM
Sprint's Avatar
oh to all you newbies.. the subwoofer, the blue bottle and the amps didn't come from home depot.. i had those before
Old Jan 23, 2002 | 09:46 AM
wicked1044's Avatar
whats a new one cost?
Old Jan 23, 2002 | 09:50 AM
Sprint's Avatar
more than a trip to home depot
Old Jan 23, 2002 | 10:25 AM
njmaxseltd's Avatar
Damm I was hoping the blue bottle came with this mod.
Old Jan 23, 2002 | 10:40 AM
97MaxGurl's Avatar
thanks everyone for your input and Bill, for diggin out the how-to tid bit
Old Jan 23, 2002 | 10:51 AM
Albertt's Avatar
My suggestion >>
I say weld a steel plate to the outside of the sparetire well and gut the bottom of the car. Then, you can mount a full size spare to the bottom and use the screw lowering system the Pathfinders use.
Old Jan 23, 2002 | 10:53 AM
Sprint's Avatar
Re: My suggestion >>
I had no problem putting a full size spare in my car
Old Jan 23, 2002 | 11:24 AM
nizmolee's Avatar
I agree, and white maxima owners are faster too!!
Old Jan 23, 2002 | 11:41 AM
sinewave's Avatar
I fixed mine a few months ago and didn't have to spend a dime. I took the panel out, sprayed it down with a garden hose on both sides, then layed face down in the garage, stacked heavy stuff on it and let it dry overnight.
The next morning it was dry and flat. I usually keep a small blanket in the trunk for various reasons, so I put it on top of the spare to fill the void. So far, no sagging and no squeaking.
Old Jan 23, 2002 | 12:56 PM
Weasel's Avatar
Re: Re: My suggestion >>
Same... I just tossed that panel and one of my GXE rims fits perfectly in the well.
Old Jan 23, 2002 | 01:07 PM
theblue's Avatar
how about carbon fiber cover to save weight j/k
Old Jan 23, 2002 | 01:09 PM
bill99gxe's Avatar
Stock 15" Maxima wheel OR 15" steelie wheel with 205/65 size tires will fit just fine in the spare tire well......Sprint's comment can give a false impression that 16" rims and up with a full size tire can fit as well, which isn't possible....
Old Jan 23, 2002 | 01:32 PM
Sprint's Avatar
Re: Re: Re: My suggestion >>
well i was talkign to the economical owners here.. not the suckers who bought SE's
Old Jan 23, 2002 | 01:39 PM
ejj's Avatar
ejj
Re: Re: Re: Re: My suggestion >>
I have a SE with a full size spare in the trunk.
Old Jan 23, 2002 | 01:41 PM
bill99gxe's Avatar
Minima owners......
Old Jan 23, 2002 | 01:42 PM
Sprint's Avatar
Re: Re: Re: Re: Re: My suggestion >>
is that full size spare a GXE wheel?
Old Jan 23, 2002 | 01:50 PM
ejj's Avatar
ejj
Re: Re: Re: Re: Re: Re: My suggestion >>
maybe
Old Jan 23, 2002 | 01:56 PM
theblue's Avatar
since the overall diameter of the wheel tires stays the same - why would it matter if its a 15" or even a 17"
Old Jan 23, 2002 | 02:06 PM
Sprint's Avatar
because the 15 inch wheel is 6 inches tall.. and the 17 inch wheel is 7 inches tall...
Old Jan 23, 2002 | 02:13 PM
theblue's Avatar
according to me you are correct
Old Jan 23, 2002 | 02:30 PM
bill99gxe's Avatar
Height is the problem.....but it's really rim width....
And I may be mistaken about claiming all 15" Maxima rims since the 3rd gen SE models and 4th gen 15" WHEELS are 6.5" wide.......but I'm fairly sure you can't go more than 205 on the width of the tire......
I know the 3rd gen GXE wheels fit with not problem on 205 width tires....
Old Jan 23, 2002 | 04:35 PM
Sprint's Avatar
skippped a couple math classes huh?
height and diameter are two different things
Old Jan 23, 2002 | 05:21 PM
Cumalot's Avatar
keith, that's a good idea. i'm going to try that with mine.
Old Jan 23, 2002 | 06:43 PM
skeelo34's Avatar
Good thing i got the gle....im not a sucka!
Old Jan 24, 2002 | 07:55 AM
Albertt's Avatar
Not when refering to a wheel >>
THe height of the wheel and tire is the overall diameter. If you're talking about about high it'll sit in the trunk, you're refering to the width of the tire/wheel.
Ha-ha...na-na...poo-poo.
Old Jan 24, 2002 | 08:03 AM
Sprint's Avatar
Re: Not when refering to a wheel >>
that must be your NYC side talking.. because your Hartford side would know better
we are speak of the wheel as it sits in the trunk.. what moron would place a wheel in the trunk while its standing upward.. to then it would be height as in diameter..
now we all know we are talking about the wheel as it sits in the trunk.. because that is the only logical way to transport a spare wheel.. so there for in this instance height is as i described it.. you are Albert Tang.. not Chris Tang.. your arguing skills are beneath me boy
Old Jan 24, 2002 | 08:10 AM
Sprint's Avatar
Old Jan 24, 2002 | 12:18 PM
sinewave's Avatar
Albertt's right; if you are talking about the height of the tire, it is implied you are talking about the overall diameter. If you are laying down and someone askes you how tall you are, do you say 6" (or in your case 4")? j/k
It's the same as the right side of the car is referenced from the driving position. If you are under the hood and indicate the right side, it is still understood as the passenger side.
Old Jan 24, 2002 | 12:51 PM
Sprint's Avatar
Keith don't make me b!tch slap you..
Old Jan 24, 2002 | 12:56 PM
sinewave's Avatar
vingodine
45
May 21, 2016 12:46 PM
JoshG
21
Sep 4, 2015 09:04 PM
jholley
Aug 30, 2015 06:39 AM
TMartinLVNV
Aug 16, 2015 01:48 PM
kirkhilles
Aug 8, 2015 10:53 AM
