aft O2 sensor
aft O2 sensor
yeah...I just installed my new GReddy Cat back system and had a hell of a time getting the O2 sensor out. I did everything, used all sorts of lube, turned the car on for a while to get it hot and tried it, turned the car off and let it cool down and then tried it. It just wouldn't budge. Finally I pulled the pipes completely out and stood on the wrench and it came out, but unfortunately I beat the sensor up pretty bad. Now I got a MIL lamp on in the car. I ran a diagnostic on the ECU? and, as I thought, I found out the O2 sensor is responding slowly (0707). I don't have enough money right now to buy a new one, is it still cool to drive around? I don't even know how much the sensor does for the car. aren't they like $170.00?
mitch
mitch
The ECM doesn't use the rear O2 sensor for adj fuel/timing...
You may have shorted out a wire... was there any exposed wires?
The GReddy kit has the O2 Bung positioned where it is too close to the heat shield... I shorted my heater circuit and popped the 15A fuse... I had to take a hammer to the heatshield and patch the wires. My MIL code was different, though
yeah, you can run with it...
But if you had repaired the wiring.. the problem should go away after you reset the MIL... Did you already do that?
yeah, the MIL is still on
If you want to go cheap you can get a universal three wire O2 sensor and wire it to the stock connector yourself. It's the rear O2 sensor, which isn't used to control emissions anyways, so no sense spending $$ for Nissan parts.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
