Cattman dyno pull graphs.....
Old Jan 25, 2002 | 06:50 PM
VeeTec's Avatar
Here are a couple of my before and after dyno graph comparisons.
Before I post them I need to add that the day before I used a gas station that apparently gave the Maxima some bad gas, I noticed it was running really bad right away and it never improved with the gas remaining in the tank. I didn't want to cancel the runs because I wanted to see what kind of difference it made. I am also going to change the plugs and the fuel filter tomorrow, and NEVER use that station again. The filter and plugs are overdue anyway.
The max h.p. gain was 16 w.h.p. at 5,500 rpms, thats around 20 at the crank! Cattmans claims are valid.
After the install the ecu was reset, and as i drove the car I noticed the performance continually get better, even with the gas problem. Not bad for only one mod. I am hoping to drop that 14.715 and increase my m.p.h. this Sunday. I will post my results early Monday morning.
http://www.eframes.com/ef-cgi/V/VeeT.../5592dyno1.JPG
http://www.eframes.com/ef-cgi/V/VeeT.../8277dyno2.JPG
Old Jan 25, 2002 | 10:38 PM
max'n out's Avatar
not bad
Old Jan 25, 2002 | 11:00 PM
Nealoc187's Avatar
SLOW
Awesome gains. I figured them to be around 10 whp... looks like I was a little low in my estimation.
CRAIG MACK, and you other guys that say "Y-pipe loses low end power blah blah..." take a close look at these graphs. The y-pipe power is above the stock power AT EVERY SINGLE POINT ON THE GRAPH. Gains everywhere.
Old Jan 26, 2002 | 05:59 AM
tifosiv122's Avatar
It's not just the Y-pipe that people complain they loose low end power...it's the Y coupled with a full cat back.
Erik
Old Jan 26, 2002 | 08:24 AM
jkratzer's Avatar
Darn it!
I've got to get me one of those y-pipe things. Only thing is I have a 2K1 which is Cali-spec. I wonder if I'll see similar gains.
Old Jan 26, 2002 | 09:22 AM
Dave B's Avatar
Not DAVEB the parts guy
Dang, if you can run a 14.7 with that little power stock, I should be doing much better with my 176fwhp/194fwtq.
Dave
Old Jan 26, 2002 | 09:53 AM
Synki's Avatar
Re: Darn it!
With cali spec, i wouldnt expect the same gains. I have a cali spec & have the Stillen Y-pipe. On our cars, there are 2 precats, if your cali, you wil only be eliminating 1 of the 2 precats. Yes thats how its designed & i dont know why.
Someone w/ a 5th gen swapped the front exhaust manifold & coverted over to FED from after being cali. He said he felt no difference in power so ...
Veetec, with the addition of this Y-pipe & your driving skills, you should be able to hit at least 14.5.
Old Jan 26, 2002 | 10:15 AM
Nealoc187's Avatar
SLOW
Dave
Look at his 60' and look at yours. There lies the answer.
Old Jan 26, 2002 | 09:58 PM
VeeTec's Avatar
Dave
I think you should be in the low 14's.
Old Jan 26, 2002 | 10:01 PM
MaximaRider's Avatar
14.4's should be attainable with your power. if ur having problems with wheelhop and traction, motormounts do do wonders
Old Jan 27, 2002 | 12:36 AM
TexMaximum's Avatar
14.7 is a crazy stock time! Congrats!
HerpDerp1919
Sep 29, 2015 02:02 PM
Sep 27, 2015 08:37 AM
