How do i jump start my car?
Old Jan 29, 2002 | 05:05 PM
_DRU_'s Avatar
for some reason, my car wont start. i tried and the starter was making the lil starting noises really really slowly. now it just goes "click click click click." i remember starting my sisters integra without another car when hers died. her car was manual. i remember like pushing the car and she sat inside and tried going into first gear while rolling or something and her car started just fine. my memory of this method is really really sketchy, can anyone explain it better or give me some links? thanks
Old Jan 29, 2002 | 05:08 PM
Sexima's Avatar
is it your battery?
Old Jan 29, 2002 | 05:13 PM
Weasel's Avatar
http://autorepair.about.com/library/...rms=jump+start
Old Jan 29, 2002 | 05:15 PM
_DRU_'s Avatar
Originally posted by Sexima
is it your battery?
i think so, my alarm *beeps* sound weaker and weaker too.
Old Jan 29, 2002 | 05:16 PM
_DRU_'s Avatar
Thanks, i know how to do that, im asking about starting my car from rolling it, or soemthing. I described it in my original post. Thanks though.
Old Jan 29, 2002 | 05:59 PM
Soon2BMaxed's Avatar
i am assuming your car is a stick, if so try this...
get in your car, turn the key to the "on" position
push the clutch in and put the car in 1st gear
get rolling or go down a hill and pop the clutch and it will start.
i had to do this last month when my starter went out, it was really easy but if u r an automagic, than u r shlt outta luck
Old Jan 29, 2002 | 06:05 PM
_DRU_'s Avatar
thanks, thats exactly what i wanted to know, i am stick by the way . i have another question though, how long do i have to drive for my battery to fully restore? or since it drained out , do i have to get a new one? thanks
Old Jan 29, 2002 | 06:08 PM
Bags's Avatar
VG Ridah's Biatch Hoe
depends , about 20 minutes should recharge it. BUT if there is a bad or weak cell in the battery it will never fully recharge.
Autozone or most auto stores will check it and your starter for free
but i am pretty sure that u have to get a new one, hey while ur at it get an optima yellow top!
Sexima's Avatar
just go around the highway for an hour and you should be set
this happened to me too today
I drove around for an hour and it's fine now
Old Jan 29, 2002 | 09:53 PM
Eric L.'s Avatar
For jumper cables, you connect:
positive from good battery to positive of dead battery
negative from good battery to a good ground (use the grounding bolts either on top of the intake manifold or on the driver side fender where the negative battery cable grounds to...do not use the strut tower nut...on my car it is not grounded for some reason..prolly due to the strut tower bar).
start car with good battery
start car with bad battery...let idle for a minute or two while revving good car at 2000RPM
disconnect in reverse order
Old Jan 29, 2002 | 11:17 PM
costcowholesale's Avatar
can't you do it with autos too? put it in N then roll then put key in "on" then snap it into "d". Woudln't that work?
Old Jan 30, 2002 | 06:29 AM
Albertt's Avatar
I don't think that it'll work >>
I believe that there is a starter kill that is activated when the car is not in Park.
Old Jan 30, 2002 | 06:39 AM
dwapenyi's Avatar
Nope. with a 5 speed, the gears are directly connected. In an auto, it's a fluid coupling, and it's built to only work in one direction, from engine to tranny to wheels, not in reverse, as roll starting would involve.
DW
Old Jan 30, 2002 | 12:35 PM
Newman's Avatar
my battery died 2 nights ago. i drove it for about 15 mins and its been fine since (so far). i guess you can drive around for an hour but ive always heard 15-20 mins should do the trick.
Old Jan 30, 2002 | 12:43 PM
sinewave's Avatar
I've found that you get much better results by using 2nd instead of 1st to bump the engine over. Also, check the water level in your battery and clean the posts before you start it. If you don't, you may not get it to take a charge and you will be doing the "bump start, drive around" process all over again.
Old Jan 30, 2002 | 01:04 PM
SuDZ's Avatar
Can all batteries be refilled? I think some "No Maintenence" ones do not allow you to do this. I could be wrong but just so if they have one theyu are not confused when looking.
SuDZ
Old Jan 30, 2002 | 01:54 PM
RedMax95's Avatar
SuDZ
ya i remember a 5.0 5spd with that problem at a car show here once, they had 5 guys push it as fast as they could and were able to start it
Old Jan 30, 2002 | 03:07 PM
DanNY's Avatar
Ad·min·is·tra·tor
SuDZ
maintenace battery - need to fill w/ water
mainteance free battery - nothing to fill
kjlouis
Nov 24, 2018 06:09 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
mrgooch
Aug 9, 2015 11:00 AM
kirkhilles
Aug 8, 2015 10:53 AM
