i can't open the front door on the right side
Old Jan 29, 2002 | 07:29 PM
easy
I think it just some mechanical problem, anyone know how much to fix that?
If i can open that door, maybe i can take it apart and fix it myself?
anyone know how to do that?
Thx a lot.
Old Jan 29, 2002 | 07:42 PM
Eric L.'s Avatar
Can you open it from the inside? You should check to see whether it is the door latch or the lock that is broken. Generally if it is the latch, you can still open the door from the other side (i.e. inside or outside). If it is the lock, well...that's a little trickier.
Old Jan 29, 2002 | 07:49 PM
easy
i can't open it on both side. sign.
Old Jan 29, 2002 | 08:55 PM
mb1's Avatar
mb1
sounds like a 90-92 accord problem. involves drilling out the door mechanism to open the door.
Old Jan 29, 2002 | 09:17 PM
medic's Avatar
if the window still works, you can always Dukes of Hazard it
same thing happened to me, but it was just the power lock mechanism that was screwing up and holding the lock down. I played with it for a bit and it cleared itself up. onlyhad the issue reoccur about once a year. annoying, but climbing out the passenger side is cheaper then fixing the door
Old Jan 29, 2002 | 09:44 PM
Eric L.'s Avatar
That's not good. Well, I guess you gotta take it to the shop and see what they can do. If you car is new enough, the dealer might be able to help you and cover it under warranty, that is..if you can prove it was not involved in an accident which damaged the door.
Old Jan 29, 2002 | 10:30 PM
easy
No accident
my friend found the door couldn't close as usually, so I just shut it heavily, so.......
Old Jan 29, 2002 | 10:34 PM
Bman's Avatar
Do the handles on either side move or not? And you're sure it's not frozen shut from ice (depending where you live )?
Old Jan 29, 2002 | 10:39 PM
easy
yes, the handles move, and i am in FL. ice? heihei
Old Jan 30, 2002 | 06:51 AM
djmaxski's Avatar
Take it to the dealer and get the lock(s) checked
Old Jan 30, 2002 | 08:49 AM
kingston's Avatar
This problem has happened to a couple 3rd gen guys. My friends lock was like that too and one day it started working again. *strange*
I have heard you can use a really long screw driver and slide it down where the window crack and somehow pop the locking mechanism like that. After that you will have to replace the lock.
Old Jan 30, 2002 | 09:53 AM
easy
i went to the nissan dealer this morning, the guy told me i should pay $300 to fix it.
i back home so frustrate......
then, I found a splint, insert it into the latch through the gap of the door, and, haha, it works, the door opened and works well now.
thx!
Old Jan 30, 2002 | 01:11 PM
Albertt's Avatar
I say >>
Weld the doors shut, paint it orange and call it the General Powell.
Old Jan 30, 2002 | 01:18 PM
All123Pro's Avatar
Re: I say >>
I am almost certain it was called the Generel Lee
Old Jan 30, 2002 | 01:37 PM
RedMax95's Avatar
Re: Re: I say >>
i will second that
Old Jan 30, 2002 | 07:27 PM
kingston's Avatar
Woah cool stuff it worked!!! When my friend had that problem I couldn't find a screw driver long enough. You should thank Kaleb. He was the one that gave me the tip when my friend had the problem with his max
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
delerium75
Aug 19, 2015 11:08 AM
shaunkey1
Aug 18, 2015 10:09 PM
kjm900r
Aug 5, 2015 07:14 AM
