Nitrous fed Auto 1/4 Mile Times...
#41
Originally posted by mzmtg
Once again, your post has contained no useful or new info. The only thing you seem to be able to contribute, other than simply repeating what others have posted, is poor grammar and bad spelling.
young grasshopper...
![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
#42
Slicks or Drag Radials are the only way to plant that power down. Bigger rims/tires might be heavier but will just kill my time. Notice how all people at the track use smaller rim/tire setup.
Gripping is all in the tires, not rims.
If bigger was better, would pro's do it then?![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
Smaller rims also change my final drive ratio. It causes my car to shift earlier meaning i stay int eh power band more. Redlining does nothing for autos. Why redline while you are already dropping in power. Yes, you might be lower in the next set of rpms but your also going to have more torque at lower speeds. SO it works hand in hand.
Sprint, and you know i wont end up using bigger rims.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
#43
Originally posted by Nealoc187
My ex girlfriend has a 99 L. 12.83@108 is her best, and she just dropped $1500 on some new parts last week. Should be around 12.3@113 when she installs them and gets to the track again.
BTW, i love the first line in your sig. It is VERY true.
#44
Originally posted by Synki
Slicks or Drag Radials are the only way to plant that power down. Bigger rims/tires might be heavier but will just kill my time. Notice how all people at the track use smaller rim/tire setup. Gripping is all in the tires, not rims.
notice medic ran his best times on 17's? less wheels spin.. better traction.. we all know traction is your enemy.. but hey.. i am done talking..
![slant](https://maxima.org/forums/images/smilies/slant.gif)
#45
Originally posted by SprintMax
thats funny.. thats why TheNewClimax is getting 2.3/2.4 60fts on drag radials .. Brett is running Drag Radials and he is still not putting the power down.. .. i guess i will bring up this argument after you buy drag radials or slicks and still can't put the power down..
Exactly, I get 2.27 60' times on street tires. Why would he need DRs or slicks?
#50
I have no idea why Adam is running terrible 60fts. I dont know many poeple who have that much trouble. BB is staying w/ DR's & getting wider DR's.
I know Greg ran his fastest times on 17's. If that's the case, why did he swap to 15's when he headed to Island?
Supras & all those cars can afford to have 17's b/c they make enough power, i dont.
On the Lightning board, the guys who use DR's & Slocks arent having probs either. They are pulling 1.7-1.6 60ft's. Most of them have them mounted on 16's. The wont evne use the 17's. This explains their fast times yet low trap speeds.
I dont unerstand how 15" DR's (225/45/15) are the same size as 17" (225/45/17) Even if i was using 205/60/15 it woudl be deflated to about 19psi. I think maybe that would sit lower then a deflated 17".
Some people may see it different then i do.
#52
Re: Re: Re: Nitrous fed Auto 1/4 Mile Times...
Yea, i talked to him once. I dont understand how he was so fast for only 40 shot. I was running 14.3@97mph on a 50 shot. I mean i only have a CAI, Y-pipe, & Nitrous. Those are my only mods. I know he ran DR's on his 16's.
With an auto, it shouldnt be all that hard to get sub 2.2 60 fts on street tires. Ive gotten a best of 2.13 with my 5th gen 5 speed on stock tires and just last Saturday MaxFreak also ran a 2.13 60 ft on 16" street tires with his 5 speed 4th gen. We run at a different track than KMAX98.
Ill see if KMAX98 can email you with his exact setup.
#53
Re: Re: Re: Re: Nitrous fed Auto 1/4 Mile Times...
Originally posted by madmax2k
Im 99.9% sure he ran street 17" tires when he ran the 14 flat. But, his 60 ft time is where its all at as it was a 2.08-2.09. I think all he had was the Stillen exhaust and the nitrous.
My best on 225/50/16 streets is 2.1-ish, I have a set of 15x6 Kosei K1's and 205/50/15 BFG gForce TA DR's that I will be using this season. I am wishing for 1.9's...
#54
RWD will always be easier to get lower 60' times. This guy got a 1.8 with his 2001 2500HD crew cab 4x4 (just like mine)
2500 HD whoops up on Mustang
I've used all different combinations of wheels/tires in front, my best 60' (1.9) was with 15x8 Custom Bogarts, wrapped with Nitto Drags (225/45/15), with a *hint* of wheel spin.
You gotta find the right combo.
#55
#57
slicks will break his drive shaft eventually if he doesn't have a couple of Don's Secret Mods
![wall](https://maxima.org/forums/images/smilies/peepwall.gif)
#58
Sometimes I will end up breaking loose and burning the tires to the 1/8 mile (like at HRP on Sept 8th), but I would rather do that than break all my parts.
#59
Originally posted by deezo
Well, after all of the testing of tires he'll need to do, he'll probably have 5 sets of tires in his closet.
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
I just dont know if i should stick DR's on my 92 SE (even though its a GXE) rims or stick them on my Steel rims.
#60
I jsut dont understand how his auto pulled those 60ft times w/o some kind of higher stall TC. I know DR's will help but i dont think it can drop me .2-.3 off my 60ft time.
I will be going w/ DR's since i dont think i make enough power for Slicks.
#61
Originally posted by Don in Texas
I think its better to stick with the Drag Radials. The slicks proved to be TOO sticky. Too much traction can also bog you down off the line, and lower your 60'.
Any word on a higher stall TC or new axles?
Help this follow Nitrous guy out.
#63
Secret mods? That would be nice to share w/ me.
#64
Originally posted by Nismo87SE
That is easy, higher stall TC + VB mod + smaller tire diameter = mid 13s with 100shot. But then again he runs the JWT n2o program where as you don't. That itself could be the difference there.
I already have Don's VB which i must sy has helped a lot. Im looking into a higher stall TC. Pref around 2800rpms or so. I will be running either 92 SE rims or my 15" steel rims w/ DR's.
#65
Re: Re: Re: Re: Re: Nitrous fed Auto 1/4 Mile Times...
Thanks.![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Thanks.
#66
Re: Re: Re: Re: Re: Re: Nitrous fed Auto 1/4 Mile Times...
I had a 40"shot" from NOS, coilovers and all the stillen sway bars. a stillen y-pipe with exhaust and hiflo cat. I raced on 225/45/17 and the car wieght was 3260 with me in it.I would hit the NOS almost off the line(within 15 feet) with 26lbs of air in the tires. 2.06 60' was my best and 14.09@98 was my best time and the 1/8 mile was 8.90@79mph or something like that.If somebody can host the timeslip for me i will emial it to them. I have a scanner but no where to host it. And I have well over 600 runs at the track, so i know what works with my car and what does not.
#67
Re: Re: Re: Re: Re: Re: Re: Nitrous fed Auto 1/4 Mile Times...
#68
![EEK!](https://maxima.org/forums/images/smilies/eek.gif)
#70
Wow, is that the fastest 40 shot NOS automagic Maxima? No VB upgrade and/or high stall TC? If not,
#73
Originally posted by TILLEYS99
I ran this with a 100 shot without a bottleheater on a 45 degree day so it wast working efficently.
R/T - .834
60 - 2.425
330 - 6.3
1/8 - 9.43
mph - 78.8
1000 - 12.126
1/4 - 14.375
mph - 100.31
R/T - .834
60 - 2.425
330 - 6.3
1/8 - 9.43
mph - 78.8
1000 - 12.126
1/4 - 14.375
mph - 100.31
you get yourself a 2.2 or a 2.1 thats .4 to .6 diff off your 1/4 putting you .. 13.9 / 13.7
#74
your trap speed shows that your NOS was working great.. its that 60ft thats the problem..
#75
I know I just dont understand it, I only had the NOS for a week at that time and only ran 1 bottle through it when I as at the track it was smoking and running way to rich so I think I could have done better. I finally made a bottle heater and it made a hell of a difference but now its tme to say bye to the bottle.
![Frown](https://maxima.org/forums/images/smilies/frown.gif)
