Need help picking a tire size...
Old Feb 5, 2002 | 02:52 PM
wicked1044's Avatar
a 95 gle comes with 205/65/15 and the se comes with 215/60/15
i was wondering about putting on 215/65/15 on a gle. should i put on the smaller 60 series tire? how will it look?? i don't want a non lowered look. i'm not to sure on how the series tire affects how the wheel gap looks. thanks.
Old Feb 5, 2002 | 07:48 PM
sinewave's Avatar
It won't make a whole lot of difference which one you use.
205/65R-15 = 25.49" dia, 80.08" cir.
215/60R-15 = 25.16" dia, 79.04" cir., +1.3% speedo error
215/65R-15 = 26.00" dia, 81.69" cir., -2.0% speedo error
Old Feb 5, 2002 | 09:03 PM
Nealoc187's Avatar
SLOW
Re: Need help picking a tire size...
Go with 225-60-15s and call it a day.
Old Feb 6, 2002 | 09:39 AM
wicked1044's Avatar
on a stock wheel?
Old Feb 6, 2002 | 12:42 PM
Nealoc187's Avatar
SLOW
on a stock wheel?
Actually I was thinking of 97+ SEs which come with a 7" wide wheel. If your wheel is 7" wide, which I'm not sure if it is or not, I'd get a 225 width tire for more traction/increased performance.
Old Feb 6, 2002 | 02:56 PM
dwapenyi's Avatar
Not that it realy matter but;
If
the 215/60 is +1.3%, then
the 215/65 should be +2.0% not minus.
DW
Old Feb 6, 2002 | 03:28 PM
ru4real's Avatar
If
DW
Huh?
I think he used minus because 215/65 results in a larger diameter than stock, so speedo will read 2% lower than actual. He used +1.3% because speedo reads higher than actual.
Old Feb 6, 2002 | 03:34 PM
sinewave's Avatar
Originally posted by ru4real
Huh?
what he said
Old Feb 6, 2002 | 07:28 PM
wicked1044's Avatar
so a 60 series will look the same as a 65?
Old Feb 7, 2002 | 06:31 AM
dwapenyi's Avatar
my bad. I plugged the numbers in and you're right.
DW
what he said
Old Feb 7, 2002 | 10:10 AM
wicked1044's Avatar
so whch is it? 215/60/15 or 215/65/15.
are there any pros & cons between the two?
Old Feb 7, 2002 | 11:37 AM
sinewave's Avatar
Well, 215/65 will fill the gap a little better, will lower the miles you rack-up on the odometer by 2% and may increase gas mileage a bit.
215/60 will give you slightly better acceleration (probably not noticable, or even measurable).
Mar 12, 2020 12:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Serotta33
Sep 17, 2015 12:14 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
jfl330
Sep 4, 2015 01:44 PM
