service engine soon light???
Old Nov 14, 2000 | 09:28 PM
mikese's Avatar
I have a 98 maxima se. Four days age, my light came on and I reset the ECM. Tonight it came on again and the flashing codes was 7 long blinks, then 5 fast blinks, then 3 long blinks then 9 fast blinks. Can anyone help me here on the problem. I try the troubleshooting on the service manual and it said the evap- small leak. HELP!!!
Old Nov 14, 2000 | 10:26 PM
mzmtg's Avatar
Minister of Silly Walks
Make sure your gas cap is on tight.
Old Nov 15, 2000 | 08:48 AM
mikese's Avatar
i try.
I did that before and it went on. So this second time, I just reset it and that is where it's at now. I don't think it's the gas cap. I tighten that like a million turns. What could that code mean and what can evap- small leak means? thanks.
Old Nov 15, 2000 | 10:18 AM
NickStam's Avatar
Similiar Situation
I have a 98 GXE and about a month ago I got [P0440] - Evap Small Leak & [P1448] - Vent Control Valve. Apparently the vent control valve had seized. Since the car was under 36k miles it was replaced for free under warranty. So if your car is still under warranty go to a nissan dealership, have them retrieve the codes from the ECU with the diagnostic tool to verify the codes. By the Way, those errors should not effect the performance of the car, but the check engine light is annoying.
Old Nov 15, 2000 | 11:20 AM
mikese's Avatar
What does the code mean?
The codes was the 7 long blinks, 5 short, 3 long and 9 short blinks tell you. I thought it would be 0705 or 0309, but i have no idea. Does 0705 mean evap-small leak. the codes are the difficult part of it. Can someone please help with these codes. thank you.
vingodine
45
May 21, 2016 12:46 PM
rbaker100
Aug 28, 2015 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Flores94
Aug 11, 2015 12:53 PM
