2004 maxima
Old Aug 16, 2022 | 11:12 AM
Toucanman's Avatar
2004 maxima
I have several issues with my 2004 maxima. The car vin says it has a 5 speed transmission, but it has a 4 speed instead. We put new vss in it thinking it was a five speed. Could that be the reason I have no speedometer? I have other issues but this is what I'm trying to fix at the moment. The two sensors we replaced were on the driver side at the back of the transmission close together. I have not been able to locate any other sensor except the crankshaft sensor.
Old Aug 17, 2022 | 09:53 AM
Toucanman's Avatar
HELP!! 2004 maxima transmission. Need to know 4 or 5 speed.
My 2004 maxima has an issue with the transmission speed sensor. I'm not sure I have a 4 speed or a 5 speed. Everything I've seen makes me think it's a 4 speed but the vin says it's a 5 speed. How can I tell which one I have just by looking at it. I cant locate the transmission ID number. If it's a 4 speed then I've been putting 5 speed sensors in it. I have no speedometer and am trying to get it back.
Old Mar 14, 2023 | 10:03 AM
ritza's Avatar
Ignition Coils Melted Causing Misfire
Hello I was hoping someone can give me advice on my 2004 Nissan Maxima. I started having problems with it in Dec. 2022. I was driving home, when the battery and brake light went on. The lights dimmed and the car could only accelerate up to 20mph. Thankfully I made it to a gas station. I had to have it towed because we gave it a jump but it would not maintain a charge. I took it to Goodyear. They said it was just replacing the alternator. Then he calls me a couple of hours later and asked if I had smelled smoke when it died on me. I said no of course not. He said he would need to have it checked by another mechanic because he didn't know what was the issue. I was surprised so I went to pick up my car, he said he was so sorry and was not responsible for me taking my car. When I turned on the car, the check engine light was on and it was shaking. It died on me and there was smoke under the hood. I had to have it towed again, but this time to another mechanic. The mechanic replaced 2 ignition coils, valve cover, wires, 2-O2 sensors, struts, 2 motor mounts, and a remanufactured ECU. The old computer was not recognizing the new O2 sensors. It took maybe 3 weeks for me to get my car back due to the holidays. I have spent so much on the car. Then this past Sunday the car started shaking again and the check engine light went on. I could smell like burnt gasoline from the exhaust. I had to have the car towed. Yesterday the mechanic replaced the other 4 ignition coils. He also added a ground from the battery to the ignition coils. Is this safe? Two of the coils had started to melt and the other 2 were bulging. I had bought the 1st two that had melted at Autozone in July 2021. What can cause an ignition coil to melt and cause a fire? I picked up my car today and it drove fine. The only thing I noticed is that when I set the time, the numbers were moving slowly. Like when the car has been out in below zero weather. It seemed odd to me. Even after driving for 15 minutes, the numbers on the radio changed slowly. Is this normal? Did the battery get weak with the added ground? What should I keep my on? I don't know if I should take it to the dealer for a full inspection. All of these issues seem electrical. I cannot afford to buy a new car. Also, back in Nov. 2022, Goodyear steam cleaned the engine to check for a leak. Do you think they did something wrong to cause these issues? For sure they did something wrong with my car when I took it to them in Dec. after replacing alternator. It just doesn't make sense. What steps should I take? What would you do in my situation? I would really appreciate all your advice. Thank you very much
Maxed Out in NY
Sep 8, 2012 03:46 AM
VeeTec
May 28, 2003 07:26 AM
bglandon23
May 7, 2003 11:37 AM
