Power steering squealing like a stuck pig?/??
Old Feb 13, 2002 | 06:26 PM
Dave B's Avatar
Not DAVEB the parts guy
This morning as I backed out of the garage, I had my wheels turned nearly full lock to avoid my wife's car and I heard this nasty squeal. Once the steering wheel got within 2" of lock, the belt/pulley/pump would squeal. After two minutes of driving, the noise was no more. When I came out to my car this evening after work, I had the same noise and then after driving, no noise.
What do you guys think. The fluid level is fine. Is my belt loose? Bad pump?
Dave
Old Feb 13, 2002 | 06:37 PM
Sway1331's Avatar
Re: Power steering squealing like a stuck pig?/??
Dave
i had the same problem a while back, it turned out to be just a loose belt, easy fix
Old Feb 13, 2002 | 06:46 PM
Dave B's Avatar
Re: Re: Power steering squealing like a stuck pig?/??
Thanks. I went out and tested the belt deflection and it seems a bit loose.
Dave
Old Feb 13, 2002 | 07:09 PM
BriGuyMax's Avatar
Re: Re: Re: Power steering squealing like a stuck pig?/??
Dave
Then tighten it
Old Feb 13, 2002 | 08:30 PM
xHypex's Avatar
I recently got a squeek in my PS, but I'm not familiar with tightening belts. Are there any good links that you guys can direct me to?
-hype
Old Feb 13, 2002 | 09:10 PM
Dave B's Avatar
-hype
Adjusting the powersteering belt is complicated. I suggest that you get a Chilton's manual. It is extremely helpful and cheap, $18. There is an adjustment screw and a securing bolt. The securing bolt is tucked up and out of sight on the pump. It's hard to explain and I doubt anyone has any kind of pic showing this bolt. This is why you need the manual.
Dave
Old Feb 13, 2002 | 09:17 PM
xHypex's Avatar
I have a Haynes but I've never read about tightening belts. I guess I should.
-hype
Old Feb 13, 2002 | 10:44 PM
Sway1331's Avatar
Dave
i second dave on this one i am by no means mechanical but the chilton's book is the best, it explains everything fairly well from wiring diagrams to how to replace light bulbs or take your dash apart, definately worth the cash order one off of amazon or barnes and noble
lowpost99
Oct 26, 2025 06:53 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
