FrankenCar Dyno vids of Toronto DynoFest now available for viewing
Old Feb 15, 2002 | 10:32 AM
LEADFOOT's Avatar
I hope the server can handle the load and it can stay on for awhile.
Enjoy.
the URL is:
http://member.newsguy.com/~paperboy/dynovids.html
Old Feb 15, 2002 | 10:50 AM
BriGuyMax's Avatar
WOW...I didn't know that a bigger filter could do that much!!
Old Feb 15, 2002 | 10:58 AM
NmexMAX's Avatar
dot dot dot ...
Re: FrankenCar Dyno vids of Toronto DynoFest now available for viewing
They sound great!!! that big cone sounds freakin kewl
Old Feb 15, 2002 | 12:30 PM
speednsound007's Avatar
omg I need a 2k2
I'm gonna go ask my dad right now because that sounds amazing.
VG
PJ
Old Feb 15, 2002 | 01:08 PM
theblue's Avatar
yeah, I was there and it was amazing to see the HP difference between the supplied cone with the intake that was obviously too small, and the larger intake.
Old Feb 15, 2002 | 01:14 PM
mzmtg's Avatar
Minister of Silly Walks
I, too, was heard to exclaim "damn" when I read that.
Old Feb 15, 2002 | 01:31 PM
emax02's Avatar
Enjoy.
the URL is:
Very cool videoas! Do you know exactly what size that big K&N filter is? With that filter his 6spd is making 10 more FWHP then mine, I have to get one and dyno it in a few weeks!
Old Feb 15, 2002 | 03:20 PM
theblue's Avatar
Re: Re: FrankenCar Dyno vids of Toronto DynoFest now available for viewing
don't know the size, but it was borrowed from a GS400 (the dyno shop's owner's car) so you can see what kits are sold for that to figure it out. Honestly I would say that the size of the jim wolf one (which I have) is about the same as the GS400 one.
Old Feb 15, 2002 | 03:24 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
i used that filter when i got my 10hp gain. on the k/n website there is a formula for size of a filter and this one is within the size range, just barely but it supposed to be big enough, HOWEVER i am using a larger filter now.
Old Feb 15, 2002 | 03:34 PM
MajesticBlueNTO's Avatar
from what i remember John, the DPE Racing Dyno Tech, saying, the K&N filter from his GS400 has a 6 inch opening and is about 8 inches in length
I was standing diagonally opposite the engine (beside Leadfoot) and, believe me, the echo off the back walls amplified that sound and i had to plug my ears!
cheers
Old Feb 15, 2002 | 03:47 PM
Cumalot's Avatar
So a bigger size filter does make a difference. Hm...maybe I should get a bigger filter for my hybrid intake. Problem is determining which model filter to get. Any ideas?
Old Feb 15, 2002 | 03:50 PM
on k/n website there is a formula you can use.
Old Feb 15, 2002 | 04:02 PM
Amazing2's Avatar
Steve,
Do you mean that the ones shipping now have a bigger filter?
(as in my intake? )
Old Feb 15, 2002 | 04:28 PM
Cumalot's Avatar
Any pic of the two filter so I could see how much bigger the large filter is? I can't view the video.
Old Feb 15, 2002 | 04:39 PM
Originally posted by Amazing2
Steve,
(as in my intake? )
i'm not totally sure. i switchd mid shipment. also you car makes less hp anyway
Old Feb 15, 2002 | 04:45 PM
LEADFOOT's Avatar
Sorry, I'm pretty sure I didn't get a shot of the larger K&N. Going by memory, it was flared out more and I would guesstimate that it was 30 - 40 % larger in diameter.
Maybe you can PM akrus to email John for specs, it was taken off his car.
Did you DL the quicktime plugin? Link is on the top of the page.
Correction: Here are two pix to approximate the size difference. 'Stock' Franken is on the left.
Old Feb 15, 2002 | 05:27 PM
Amazing2's Avatar
Old Feb 15, 2002 | 08:55 PM
emax02's Avatar
Hey that "big" filter looks just like my stillen (made by K&N) filter.
I think my stillen velocity stack teamed up with the franken ram piece may be causing some turbulance in the air stream resulting in my low peak power #'s(we will see!).
I will have to get the franken MAFS adapter and see if that fixes the problem. As soon as I get my Greddy exhaust I will dyno this and also see what my RT cat did for power.
Old Feb 15, 2002 | 09:12 PM
costcowholesale's Avatar
bigger verison of gs400 filter
http://imagep.webphotos.iwon.com//10...M0.2453555.jpg
Old Feb 15, 2002 | 09:42 PM
Cumalot's Avatar
Here's a pic of the filter I'm using now on my hybrid intake. I don't think I could really go any bigger, right?
http://images.cardomain.com/installs...17_46_full.jpg
Old Feb 15, 2002 | 09:44 PM
you could get it tapered and slightly longer.
Old Feb 16, 2002 | 12:42 AM
MaxedOut's Avatar
yea that intake fromt he GS.. looks exactly like my Stillen Intake on my 95... the stillen one if pretty big too...When i bought my first intake it was the size of the "stock" frankencar intake... i didnt notice any difference
Old Feb 16, 2002 | 03:30 PM
akrus's Avatar
Thanks leadfoot
Thanks for taking and then hosting the vids. Much appreciated.
Two things need to be pointed out re: the larger filter
1) the Rod Millen velocity stack was used to mount the filter to the Frankencar MAF adapter. The opening on the larger filter is MUCH bigger than on the filter that came with the FC. The large opening is reduced by way of the Rod Millen VS so it mated up with the hose included with the FC intake. The VS was also very thin, it showed signs of being disformed, nothing sever, but evident none the less.
2) the dyno proved that there was only a 2hp difference between the original filter on the FC (http://www.cenpipe.com/~akrusvar/maxima/run5sae.jpg) and the larger filter using the rest of the FC intake (http://www.cenpipe.com/~akrusvar/maxima/run4sae.jpg). This, IMO is a small gain. The most intriguing reason to go with the larger filter is the sound - deeper sounding and starts growling quite a bit earlier.
In the end, I'm not sure the added cost of the RM VS would make me jump for joy regarding the 2hp, I might be more excitable gaining the deeper growl.
Albert
AaronL
Aug 8, 2020 10:31 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
BrandonCause
Sep 20, 2015 10:20 PM
