'Normal' Setting for TB cables..?
Old Feb 16, 2002 | 12:54 AM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
How can I check if the TB cable setting is where it's supposed to be?
tks.
AnGe
Old Feb 16, 2002 | 01:13 AM
Nismo's Avatar
just make shure that when the accelerator pedal is all the way down that the butterfly is all the way open. there souldnt be any freeplay in the pedal after the butterfly is at WOT or else you will stretch the cable and it might snap
Old Feb 16, 2002 | 02:07 AM
Confused's Avatar
Permanent Maxima.org Resident
you should think of these things during regular business hours... make sure it's not loose or coming up above the half moon... (_i_)
Old Feb 16, 2002 | 02:21 AM
jdmmax's Avatar
hey ange i called that number and your guy didn't get back to me on those wheels. it seemed to be a pager
Old Feb 16, 2002 | 08:39 AM
NotNew!!NewSN!!'s Avatar
to check the WOT cable length that do i just have someone floor my car when its turned off, or does it have to be on (which would be annoying as hell)
Old Feb 16, 2002 | 10:05 AM
brubenstein's Avatar
Man, do you guys have things backwards! The most important thing when adjusting the throttle cable is to make sure the butterfly full shuts when the gas pedal is not depressed. There is enough travel in the rest of it to always full open the trottle (so long as the adjustment isn't completly fould up).
Now, to adjust it so you don't kill anyone, with the throttle fully closed, the cable housing is adjusted so that there is a couple of mm side-to-side slack in the inner cable.
James92SE
142
Jan 2, 2024 09:23 AM
alphakaoz
Sep 30, 2015 07:33 PM
RWCreative
Sep 21, 2015 11:01 AM
240tomax
Sep 13, 2015 03:28 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
