Installed Harlan Shift Light (Pics)
Old Feb 17, 2002 | 09:22 AM
Ants97SE's Avatar
Well I followed Cheston's directions for the autometer and made some changes of my own for the Harlan Shift light. On the back of the guages, I put a wire on the IGN screw, the TAM screw and the GND screw. Basically all of the wires are in a line, no cutting. I don't like cutting into my car. Very easy install, didn't take long at all. The supplied wire was just long enough to mount it on my steering column. Programming it was simple too.
http://www.digitalfury.org/images/021702/harlan1.jpg
http://www.digitalfury.org/images/021702/harlan2.jpg
Old Feb 17, 2002 | 09:28 AM
NickStam's Avatar
Re: Installed Harlan Shift Light (Pics)
when does the light go on? redline? or can you custom program it?
Old Feb 17, 2002 | 09:33 AM
Ants97SE's Avatar
The shiftlight comes with a spreadsheet of DIP switch settings on the circuit board you set on the shiftlight inside the tube from 500 to 12000 in 100 RPM increments. You set the RPM setting and the amount of cylinders in the engine and you are all set. You can find the shiftlight below. Mines set for 6200 and it works great.
http://harlan.sketchy.net/store/store.html
Old Feb 17, 2002 | 09:35 AM
NickStam's Avatar
so you can set it at 1000 if you wanted to? ha
Old Feb 17, 2002 | 09:36 AM
Ants97SE's Avatar
Basically... for all you granny shifters out there.
Old Feb 17, 2002 | 11:52 AM
maximumsportZ's Avatar
Lives in a 350Z
http://harlan.sketchy.net/store/shif...hiftLight.mpeg
Old Feb 17, 2002 | 12:13 PM
Sprint's Avatar
looks nice Ant..
Old Feb 17, 2002 | 01:25 PM
Ants97SE's Avatar
Thanks Sprint, nice X in your sig.
Old Feb 17, 2002 | 01:33 PM
irvine78's Avatar
ooo...i could use one of those...i need to stay clear of my rev limiter...
Old Feb 17, 2002 | 06:55 PM
Colonel's Avatar
Old Fuddy Duddy
Yup, its easy to install and great.... I used it for the EXACT reason you mentioned....keeping from bumping rev-lim. Done its jobe. Set it to 6200 and I am golden.
Although I made a custom mount and put it up by the rearview...You cant see it from outside the car.
CorollaULEV
30
Aug 9, 2021 08:11 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
