performance springs
Old Feb 17, 2002 | 04:19 PM
maxman00's Avatar
performance springs
I was wondering if you needed to purchase new struts if you want to install perf springs, or will the perf springs work with the stock strut setup??? I only ask because I have a 2k max se and the suspension seems fairly stiff as it is.
Old Feb 17, 2002 | 04:32 PM
NickStam's Avatar
Re: performance springs
if you think that the standard equipment is stiff, it's only going to get stiffer with perf. springs.
Old Feb 17, 2002 | 05:41 PM
Greg's2kGLE's Avatar
You can have aftermarket springs with stock struts. Your struts won't last long after that. Then you'll need new struts. Like Nick said, aftermarket springs are only going to get stiffer.
Old Feb 17, 2002 | 07:59 PM
maxman00's Avatar
thanks for the advice! I know that it is going to get stiffer, and that is what I want. I was just wondering about use of stock struts in conjunction w/ performance springs. In a nutshell I want to be able to lower the car, get a little more performance out of it, and do so without spending too much money.
Old Feb 18, 2002 | 01:31 AM
Nismo's Avatar
you can but they are going to bust sooner or later. some ppl have used stock struts with performance springs and have no problems "yet" but its wiser to buy the whole spring/strut setup and install it at the same time which will save you money from the shop. unless you do all the work yourself.
Old Feb 18, 2002 | 10:26 AM
maxman00's Avatar
thanks for the advice. overall it does sound like the best thing to do, and it is what I will do when I change over. I wish nissan would wake up and sell the stock SE's a little lower!
I like that 10 sec car ......that was the first car I ever owned!
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
