Uh-Oh...I have a bubble in my tire!
Old Feb 17, 2002 | 04:47 PM
Vyrus's Avatar
Is it okay to drive with it? The rim is fine, but there is a definitely a little bubble in the tire. Is there any way to fix it and how much should it cost?
Thanks,
Cyrus
Old Feb 17, 2002 | 04:51 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Re: Uh-Oh...I have a bubble in my tire!
Thanks,
Cyrus
get a new tire.
NickStam's Avatar
Re: Re: Uh-Oh...I have a bubble in my tire!
it will only get worse.
Old Feb 17, 2002 | 04:53 PM
Vyrus's Avatar
Is there no way to repair it?
-Cyrus
Old Feb 17, 2002 | 04:57 PM
-Cyrus
get a new tire, semi soon, and dont' drive over like 100
Old Feb 17, 2002 | 05:02 PM
Chunger's Avatar
My other car is a Hybrid
-Cyrus
it can't be repaired... that is now a weak spot in the tire... get it replaced soon.
Especially if it is on the sidewall.
Old Feb 18, 2002 | 07:21 AM
Stealth Max's Avatar
Thanks,
Cyrus
The belts inside the tire is bad. You need to replace the tire soon or you may experience a blow out. If your tire is new or have road hazard warranty then you can get it replaced for free or minimal cost depending on the tire wear.
Old Feb 18, 2002 | 07:29 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
-Cyrus
Your car will start violently vibrating if you drive fast. This happened to me in my old car.
Mishmosh's Avatar
BTW, what tire make is it so I know what to avoid? My dad used to have firestones which did that soon after he purchased it and they refused to replace it saying such a defect can result from driving conditions or behavior. What crap!
Old Feb 18, 2002 | 08:03 AM
sascuderi's Avatar
just went through this....
A ~1 year old Goodyear tire on mh wife's accord developed a bubble on the side. Had 10,000 miles on the tire. The Goodyear dealer gave us a new tire for $20.00. What they do is look inside the tire and if it looks like a flaw in the tire (as opposed to you hitting a pot hole and braking the belt) then they only charge you for the "used" portion of the tire,ie they pro-rate the new tire.
Old Feb 18, 2002 | 08:13 AM
1BADMAX's Avatar
Well you may as well avoid every tire company on the face of the earth because i'm pretty sure that this has happened to them all at least once. I'm not trying to be a smartass, but the only reason I wouldn't buy some company's tire's is if they had a long history of problems. Just my 2 cents though.
Old Feb 18, 2002 | 11:12 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
every tire manufacter has had some sort of defect. Whether Goodyear, Michellin, or Firestone. I work for Firestone and sometimes bubble on the sidewall is not a defect but from driver or road conditions.
Old Feb 18, 2002 | 12:24 PM
dashingMax's Avatar
Re: just went through this....
Did you have original reciepts for the tire?
I have, I think, a similar problem with one tire. They are on my stock rims right now for winter. I can feel the rear driver side of the car shake up and down and is directly proportional to the rotation of the tire. The tires are Cooper Cobra. I do not have original reciept, so I am wondering if it will be covered!
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
