Attn: SC Guys- I have a question
On your SuperChargers do you guys have an oil return hose?
If so where do you have tapped into? I'm wondering because I'm about to get my hose tapped and I want to make sure there's not a better place.
Alex
Alex
Re: Attn: SC Guys- I have a question
Alex
Alex
Alex
Alex
Question... Can you give me some details on your FMIC? Brand, Size, etc? Thanks!
Turtle turtle... Moderator
![](https://maxima.org/forums/images/smilies/support.gif)
Is that a part that can be ordered? does anyone have pix of this?
I hope I'm not bugging you guys too much.
dont tap it the same way that the Stillen Supercharger goes, reason being is your oil return line should be lower then where the turbo sits so oil can return to the pan. i think you mounted your turbo pretty high but still...
Re: Re: Attn: SC Guys- I have a question
Originally posted by Chunger
You'll probably need to tap/weld a drainback for your turbo since it's on the opposite side as the SC kits.
Originally posted by Turbo95Max
Alex
Alex
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Oh ok. Where did you tap yours? Being that it's that high won't the connection be lower no matter where I put. I mean the the Turbo sits so high it could act as a snorkle too.
I also would like to know where you tapped yours into Turbomax!
Thanks!
$50 per person and ill release that info!! hahah juss kiddin, well you guys have it setup different from me, in my opinion, and i mean no offense, but i think its pointless to have the turbo sit so high up, you have to relocate the battery, run more piping and stuff as well. Anyways, mine is tapped on the upper oil pan, where it should be. The only thing is youll have to drop the upper pan and weld the bung(whatever you call it) onto the pan. Where it was tapped is about 14 inches from the Turbo.
We took the Pan off yesterday morning to tap in to it but I wanted to make sure there wasn't a better place. We were thinking of getting a catch can w/ filter to make sure no oil backed back into the Turbo.
Thanks for the Info Turbo95.
Originally posted by yo_its_ok
wonderful two piece design...worse comes to worse, custom sheet metal pan holding 6 qts of love juice for the motor and turbo. Run a remote oil filter w/ cooler.
Looking good U-M-t
Hi Matthel, I am getting the ZOOM mirror soon, as soon as I can go to Koreana Cargo to pick up the rest of my stuff![naughty](https://maxima.org/forums/images/smilies/naughty.gif)
Looking good U-M-t
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Alex, what you talkin bout putting a filter on the turbo?>
Unclejunebug
04-02-2016 05:42 AM
Stagnet04
10-11-2015 08:16 PM
