Should this hose be connected to anything?...
My friend just put a breather on my car ( ) and he said he doesn't know if this was connected to anything. It is the one circled in blue. Also does it matter if I plug up the old hole in the airbox (where the no-longer-used hose connected)?
Thanks,
Cyrus
Thanks!...
Originally posted by 1HOTMAX
that's just a free hose that takes air for a sensor or something like that, when i did my CAI, i thought i forgot to connect it to something, i just pointed it down and it stays there from that point.
-Cyrus
and you MUST plug up the hole on the resonator that used to connect to the crankcase or else your MAF sensor will be reading wrong air flow readings since you now are allowing air(also unfiltered) past the sensor.
Re: Thanks Nismo...
Originally posted by Santa
Shouldn't there now technically be more airflow because the hole was plugged (the tranny is not stealing any air anmore)?
-Cyrus
-Cyrus
I dont understant what you just said about the tranny. the tranny has nothing to do with the crankcase breather hose.
leave the hose pictured above unplugged and plug the hole thats on the intake resonator that used to have the crankcase hose on it.
Re: Should this hose be connected to anything?...
Thanks,
Cyrus
Thanks,
Cyrus
Re: Re: Should this hose be connected to anything?...
Originally posted by TaiwanMaxima
That's the same exact breather line that was not connected when I hooked up my Franken Car Intake. Is it ok to leave it like it is?
http://forums.maxima.org/showthread....threadid=72447
Here are some pictures of the hose unhooked:
http://briefcase.yahoo.com/bc/jayson...src=bc&.view=l
click on maxima folder
so just leave this hose alone?
Licensed to Spell
:o)
Yup, the same thing happened to me when I was installing the charger. We were completely done and wrapping things up and we saw that hose just hanging there! Freeked me out because I was very careful remembering anything I disconnected. I immediately checked EVERYWHERE on the stock airbox for a possible connection point. Nothing. I looked at every picture I could find in the Chiltons and Haynes. Every single picture shows it at such an angle that the free end is always hidden! Ahhhhh!! I eventually surfed the net looking for pics of 4th gens w/ their hoods popped. Right as I finally found one that actually showed the free end, and the picture was half loaded, my connection went down for the night. Talk about just in time.
yea, I got pretty frustrated after installing the FC intake cause i coudn't figure out where the hose connects to. I refered back to my old airbox box, but nothing. Now, I feel alot BETTER.
Thanks for the feedback~
HerpDerp1919
09-29-2015 02:02 PM
