Guys could ya help me out a little
Old Feb 28, 2002 | 06:26 PM
Conrad283's Avatar
I need a truck
i'm getting my AGX's tomorrow and i would like to put them on my 96 myself...i did a search and it cost people upwards of 300 to get it installed ... this is what the search gave me:
Here are the basics on installing springs and shocks:
1. Equipment: Jack stands, breaker bar, spring compressor, metric sockets and torque wrench.
2. Remove the front tire. Remove the two 17mm bolts at the bottom of the front shock assembly. The nuts are 19mm. Open the hood and remove the three 14mm bolts at the top of the shock tower.
3. Once the bolts have been removed take out the shock assembly.
4. Install the spring comressors. One on either side of the spring and tighten.
5. Now remove the large bolt at the top of the shock assembly. DO NOT REMOVE THE BOLT AT THE TOP OF THE SHOCK ASSEMBLY WITHOUT THE SPRING COMPRESSORS INSTALLED.
6. Take apart the shock assembly and besure to layout the part on the floor. Keep them inorder so it will be easy to reassemble. Cut the bump stop. One notch will be fine. The small narrow end.. take the tip off.
7. When swapping out the spring besure to transfer the rubber sleeves that are on the top and bottom of the spring.
8. Install the spring on the shock assembly so that you can read the lettering. The lettering represents the top so you don't install them upside down.
9. Put the shock assembly back together and install the center lock bolt. The center bolt gets torqued to 50 ft-lbs. 50 ft-lbs. is for the front shocks only. The rear shock center bolt is hand tightened.
10. Reinstall the shock assembly and torque the top and bottom bolts to spec. Top strut tower bolts are 30-40 ft-lbs. The front lower bolts are to be torqued to 110 ft-lbs.
Repeat the same procedure for the rear install. There are two 12mm rear strut bolts per side. They get torqued to 12-14 ft-lbs or hand tightened. The lower rear shock bolt is a 17mm. The nut is fixed to the suspension. The torque spec. for the rear bolt is 80 ft-lbs. Only the rear Tokico shocks come with upgraded parts besure to install the new parts.
is this all i need to know for installing shocks & springs? or is there more to it?
does anyone know of any links that could help me out?
Old Feb 28, 2002 | 08:47 PM
skeelo34's Avatar
Re: Guys could ya help me out a little
[QUOTE]Originally posted by Conrad283
[B]i'm getting my AGX's tomorrow and i would like to put them on my 96 myself...i did a search and it cost people upwards of 300 to get it installed ... this is what the search gave me:
Its easy....without reading your long post this is what you need.
Breaker bar (15 bucks), jackstands (10 bucks for 2), spring compressors (autozone rents them to you for 40 bucks, you get the 40 bucks back when you return them). A ratchet set is helpful. The job is easy, just takes time and patience. I didnt even use a torque wrench, just was careful not to overtighten. It helps to have a friend.
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 7, 2015 07:26 AM
Max139617
Sep 6, 2015 06:02 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
