indiglow gauge dimming question - i searched
Old Mar 5, 2002 | 08:13 AM
grunge's Avatar
I just ordered some indiglow gauges and i was wondering why they didnt wire the gauges into to dimmer switch so that the factory dimmer would dim the indiglow... I.E. instead of getting power from the dimmer BULB get power from the dimmer contol. This way you could just turn the dimmer that came with the gauges all the way up and use the dimmer on the factory to contol the voltage sent to the gauges.
Is there a reason this wont work?
Old Mar 5, 2002 | 08:25 AM
JAIMECBR900's Avatar
Re: indiglow gauge dimming question - i searched
the gauges already come with a "dimmer" control, why would you want another?
Old Mar 5, 2002 | 08:35 AM
grunge's Avatar
Re: Re: indiglow gauge dimming question - i searched
Because the dimmer they come with would need to be mounted in order to be accessed. And it would look tacky. Why not just use the one already in the car, I dont see a point to having two dimmers.
I bought the 2 color gauges and am planning on putting it inside teh dash where it is inacessible.
Installing it to the factory switch would be more professional and more effecient.
Old Mar 5, 2002 | 08:41 AM
Re: Re: Re: indiglow gauge dimming question - i searched
I understand; some people have mounted the dimmer and color switch under the steering column to have access to it but be out of sight.
Old Mar 5, 2002 | 08:45 AM
grunge's Avatar
Re: Re: Re: Re: indiglow gauge dimming question - i searched
I dont see why you couldnt just wire it into the dimmer switch iteself... and use that to regulate the voltage.. if thats all the dimmer that comes with the gauges does than that would work.
If however the dimmer that is included is an inverter that will ONLY work with 12v and teh dimmer is after the iversion and does something other than regulate voltage than it wont work.
I am just wondering if it will work off the factory dimmer. Has anyone experimented/ tried this?
Old Mar 5, 2002 | 08:49 AM
Re: Re: Re: Re: Re: indiglow gauge dimming question - i searched
the included dimmer does look like an inverter and it does come after the inverter. Not sure if does anything more though.
Old Mar 5, 2002 | 10:02 AM
grunge's Avatar
Re: Re: Re: Re: Re: Re: indiglow gauge dimming question - i searched
Hmmm... I think ill call www.beingseen.com they have a tech guy there that has worked with el flatlights for quite some time.
Old Mar 5, 2002 | 10:09 AM
grunge's Avatar
Re: Re: Re: Re: Re: Re: Re: indiglow gauge dimming question - i searched
called him, he said that if these gauges are anything like the flatsheet lights he sells (probably are) then yes you can just wire them directly to your dimmer.
but im still interested if anyone has done this.
Mar 12, 2020 12:06 AM
97_GXE
20
Sep 17, 2015 08:12 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
minsbang
Sep 5, 2015 05:36 AM
