Stillen lip installation- why dont I have the screws in my fender???
Old Mar 10, 2002 | 09:46 PM
Nismo's Avatar
I was reading on maximadriver about the how2 install the stillen Lip, it says there should be a screw on each fender thats the exact spot to screw on the lip. My problem is that I dont have those screws! There isnt even a hole where it says its suppose to be. I have screws on the fender but they are right next to the clear corner lenses which is way to high for the lip to be screwed on.
heres a pic of a guys stillen lip and the screws which I dont have that are on the lip and the only screws that I have are the ones above the lip
http://www.custommaxima.com/Images/Fenders6.jpg
Old Mar 10, 2002 | 09:48 PM
1MAX2NV's Avatar
Use some stainless steel screws and make the holes by using a drill.
Old Mar 10, 2002 | 09:51 PM
Nismo's Avatar
Is this what you have to do? or am I the only one with out any screw holes there? thanks
Old Mar 10, 2002 | 10:15 PM
BlkCat
I discovered that too when I test fitted the lip. I drilled some holes and used rivets.
Old Mar 10, 2002 | 11:40 PM
Chunger's Avatar
My other car is a Hybrid
You're supposed to use Pop Rivets... that's what I used... but you can use screws instead.
Old Mar 10, 2002 | 11:53 PM
carnal_c30's Avatar
Former Sponsor
you can use screws, not too long and pilot the hole first
ummm a good way to do it without putting many screws in the body of your car is to turn your wheel to the right and put one screw in the end of the fender hmmm lke the fender lip... and use double sided tape on the rest... and ofcourse put another screw on the other side
dude your car is looking better and better everytime I look
Old Mar 11, 2002 | 12:11 AM
Nismo's Avatar
thanks!
and thanks everyone for the info. I was getting scared thinking I was the only factory freak with no screws
Old Mar 11, 2002 | 07:36 AM
1MAX2NV's Avatar
I have installed many types of lip on many different cars. I never seen a front lip with holes in it. Rivets or sheet metal screws will both work.
Old Mar 11, 2002 | 12:42 PM
Nismo's Avatar
I installed many type of lips and many different cars. I never seen a front lip with holes in it. Rivets or sheet metal screws will both work.
I was talking about holes in the fender, not holes in the lip itself. thanks
Old Mar 11, 2002 | 03:33 PM
Synki's Avatar
I didnt have holes. I had to drill holes & use the supplied screws. Use the self tapping screws.
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
doctorpullit
Mar 29, 2016 11:08 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
Garrettz459
Sep 28, 2015 02:50 PM
