AutoMeter EGT guage question
Old Mar 11, 2002 | 08:02 AM
ejj's Avatar
ejj
I installed the guage this weekend and it works perfectly while running...however, when I turn the car off, the needle on the guage jumps up! It usually hangs out around 1200 or so when there is no power to it.
Once I turn the power back on, the guage drops down to the correct temperature.
Anyone ever seen anything like that?
Old Mar 11, 2002 | 09:57 AM
AznStevie's Avatar
you are fine..mine does the same thing hehe..
Old Mar 11, 2002 | 10:00 AM
ejj's Avatar
ejj
any ideas why?
Old Mar 11, 2002 | 10:13 AM
AznStevie's Avatar
not really? =( mine doesn't stay around 12000 hehe..mine sits around different temp when the car is off
Old Mar 11, 2002 | 10:15 AM
1MAX2NV's Avatar
Mine does the same thing. If you really want to know why it does that, give autometer a call.
Old Mar 11, 2002 | 02:27 PM
SuDZ's Avatar
This is somethign that is common in many companies setups. Maybe it is readon ohms somewhere. I think that is how the gauges ooperate is by reading that and then responding with the needle position.
SuDZ
Old Mar 11, 2002 | 04:32 PM
bullseye's Avatar
What size probe did you use (3/16 or 1/4)? Where did you install the probe. Where did you install the gauge? What temps do you get under WOT? Cruising at highway speeds? Around town? Thanks.
Old Mar 11, 2002 | 04:48 PM
ejj's Avatar
ejj
Thanks guys. Glad to hear its normal.
I got this probe so welding would not be needed in the install.
Guage is installed on the A-pillar. Probe is in the front most bank, as high on the y-pipe as I could get.
WOT I've gotten up to 1400, highway around 75 gets me about 1200-1300.
Old Mar 11, 2002 | 06:33 PM
Ramius83
Yeah, like said before, it is normal. Most "good" electrical gauges do this. Some cheaper ones do not.
Old Mar 11, 2002 | 10:19 PM
Neo Max's Avatar
Am I missing something here? I thought over 800 degrees was bad or am I talking celcius and you're in fahrenheight?
Old Mar 12, 2002 | 06:18 AM
ejj's Avatar
ejj
Yeah. My guage is F and over 800C is bad. 800C is about 1475F.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
