I just painted my grill body colored, pics and info inside
Old Mar 13, 2002 | 02:02 PM
emax02's Avatar
I was painting my new franken ram piece body colored and decided to pain my grill too! A few weeks back I has a local paint shop make a high end spray paint can of color matched paint(sterling mist). So I removed my grill by removing the 3 little ten MM bolts. I used masking tape to cover my nissan emblem so that paint would not get on it and then I fired away, 1 coat 2 coat and then a I hit it up with a few coats of clear coat. The result is incredible! It looks like a profesional job, the paint matches very niceley too!
Heres some pics(not the greatest). I took pics of me doing the whole thing too but I had my flash off so they came out horrible.
Old Mar 13, 2002 | 02:04 PM
clee130's Avatar
Looks good.
Old Mar 13, 2002 | 02:34 PM
DanNY's Avatar
Ad·min·is·tra·tor
where did u get this paint from? cost? do they ship?
Old Mar 13, 2002 | 02:37 PM
Maximamike's Avatar
I must say that you've made quite a nice amount of changes since I saw your green 95 Max at the Mass meet. You're doing a hell of a job on your 2k2. Keep up the good work, bro!
Old Mar 13, 2002 | 02:52 PM
PhatGuy
Looks awesome!
Does the 2k2 grille remove easier than a 2k-2k1?
redmaxpa007's Avatar
i SeE what you did therE
looks good ..
hope it holds up.. bugs, stones, and other debri will chip it..
Old Mar 13, 2002 | 02:54 PM
TellschMax02's Avatar
Do I see the yellow lenses back in your headlights???
You take any pictures of the ram painted?
Nice work...again...keep on blazing those trails...
Old Mar 13, 2002 | 03:15 PM
deezo's Avatar
Just a suggestion, you could go to www.paintscratch.com and they can match your paint and put it in a spray can. This is how I painted my plastic valvehead cover. Pic is in my sig.
Old Mar 13, 2002 | 03:22 PM
Stealth Max's Avatar
The grille looks very nice. We want more close up pics.
Old Mar 13, 2002 | 03:43 PM
DanNY's Avatar
Ad·min·is·tra·tor
i know about paintscratch.com...just looking for a slightly cheaper alternative.
thanks!
Old Mar 13, 2002 | 05:13 PM
Newman's Avatar
Re: I just painted my grill body colored, pics and info inside
im about to do this to my car too. a body shop at home quoted me $93 to paint the grill if i took the grill off myself and took the emblem off (does it even come off?) i havent gotten a chance to ask any other body shops yet. how much was the paint and clear coat all together?
Old Mar 13, 2002 | 06:04 PM
emax02's Avatar
The paint ran me about $32(every paint mix is diffeent though), they also gave me a paint jar of body colored paint too. The shop is called "Providence Lacquere & supply center inc", I don't know the # ands I'm not sure if they ship. The paint they use I think is called Dupont, the same paint Nasscar uses.
Old Mar 13, 2002 | 06:06 PM
emax02's Avatar
Originally posted by PhatGuy
Looks awesome!
I don't know how the 00-01 grill is attached. My grill has 3 10 mm bolts holding it on and a few clips. Just remove the 3 bolts and pull really hard and it pops off, it took about 5 minutes to do.
Old Mar 13, 2002 | 06:08 PM
emax02's Avatar
I will get some pics of the ram tomarrow once it's installed. My orange lights are not back in the headlights, I have orange bulbs in there so the flash makes it look all orangy. I wanted to keep it legal.
Old Mar 13, 2002 | 06:11 PM
emax02's Avatar
Re: Re: I just painted my grill body colored, pics and info inside
The emblem does not come off to my knowledge, just use some masking tape and seal it off. The paint and clear coat was about $40, the paint job looks proffesional.
Next up.. body colored headlights
Thanks for all the complements guys!
Heres a lousy pic of just before I started painting, if you look closely you can see how I taped the emblem up.
Old Mar 13, 2002 | 06:15 PM
Newman's Avatar
Looks awesome!
2k/2k1 grill doesnt come off period people have said. the grill and bumper are supposedly all one piece.
Old Mar 13, 2002 | 06:27 PM
Maximamike's Avatar
Thin out some silver paint and put it on there. It should cover the orange but the light will still shine through. They make bulbs like this but I don't know if they have them in that size. They're made by Phillips and they're called Silver Visions. They would look killer in your ride
Old Mar 13, 2002 | 06:34 PM
emax02's Avatar
Thanks for the advice Mike. I was thinking about doing that but I need to find a place that sells translucent silver paint first .
Old Mar 14, 2002 | 12:12 PM
Newman's Avatar
i just went to some body shops here at school. some little place called Dan's Body Shop quoted me $85 but he couldnt do it until April 10th. After that i went to the Chevrolet dealer here and their body shop told me $45 or $50 and they can do it on monday. a body shop at home told me $93. soooooooooo, looks like im going to Chevrolet.
pretty inexpensive and i have a feeling it will improve the looks of the car a lot. emax's definitely looks nice.
Old Mar 14, 2002 | 12:27 PM
SuDZ's Avatar
Looks real nice. Makes it look much more even with the rest of the car.
SuDZ
Old Mar 14, 2002 | 04:24 PM
shane's Avatar
what about a 4th gen grill(96)is that hard to remove and paint
Old Mar 14, 2002 | 04:42 PM
emax02's Avatar
4th gen is even easier to do.
Old Mar 14, 2002 | 04:57 PM
shane's Avatar
How do you remove the grill grom a 96 then and how long does it take to remove install and paint,and what type of spray paint can i use (black)thanks
Old Mar 14, 2002 | 05:06 PM
emax02's Avatar
Theres 4 clips on a 96 grill, you just have to unclip it. You can buy color matched paint from http://www.paintscratch.com (as said above). The time it will take is dependent on how quick you are.
Old Mar 14, 2002 | 05:33 PM
Wizeguy's Avatar
Tip for the 95-96 guys. Look at the nissan emblem. See the hole there? Insert flat head screw driver and twist 1/4 turn.
Old Mar 14, 2002 | 06:36 PM
shane's Avatar
how do i put those clips back in i took them out and now cant put them back in (96)maxima
Old Mar 14, 2002 | 06:42 PM
Newman's Avatar
they should just snap back in. nothing more.
Old Mar 14, 2002 | 08:02 PM
NYCe MaXiMa's Avatar
man
your car is F-in sweet. I love every little thing you did to it, I wouldn't do it any differnt if I had it Great job.
By the way, I painted my stock chrome 98 GXE grille black.. I used **** paint for it too, and surprisingly it held up pretty well.. i had to give it some touch up sprays here and there twice, because of tiny chips.. but I used a primer and a flexible bumper and moulding trim black paint from Pepboys, didn't even use clear coat.. came out really nice..
Old Mar 15, 2002 | 01:23 PM
emax02's Avatar
Originally posted by NYCe MaXiMa
man
Thanks bro, thats sounds cool.
Heres a close up pic of my grill.
Old Mar 15, 2002 | 02:30 PM
Newman's Avatar
is the chrome part of the 4th gen GXE grills similar in material/coating as the chrome window trim on the 5th gens? i wanted to get mine painted black but the body shop told me that it wouldnt adheer very well and would probably flake off.
Old Mar 15, 2002 | 02:38 PM
SEguy182's Avatar
it looks great emax, i was just thinking yesterday what the 2k2 max grill would look like body color, i saw it on and altima to. It looks very nice.
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
Quickgtp
Aug 27, 2015 02:13 PM
