learned something useful in chem class
Old Mar 15, 2002 | 09:15 PM
MaximaPower's Avatar
OT
my chemistry professor said something the other
day about jump starting a car. he said ure suppose
to only clamp the positive on the bad battery and put
the other clamp on the metal part of the car....and
clamp the other end of the cable to
both + and - on the good battery...i never knew this
well he said something about if u clamp both + and -
on the bad battery (like how most ppl do) there's a
risk of a lil explosion....i'm not too good in chem
so i dont really understand wat he said but it's something
with the sparks and the hydrogen that can cause an
esplosion
Old Mar 15, 2002 | 09:18 PM
97BlackMax's Avatar
Re: learned something useful in chem class
Originally posted by MaximaPower
OT
esplosion
yeah, that is correct...you're supposed to clamp the negative end that would go to the bad battery onto a metal part to ground the system...there's been cases of exploding batteries when people did not follow that process...not exactly fun
Old Mar 15, 2002 | 09:24 PM
Re: Re: learned something useful in chem class
i feel like a big idiot for not knowing that...i never
had to jumpstart my car b4 and i'm glad i haven't cus i woulda
jus clamped both of them like a foool
Old Mar 15, 2002 | 10:38 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
i jumped cars many time, including my 95 a couple times and i always do it the wrong way, i'm living on the edge, you can help yourself from falling.
Old Mar 15, 2002 | 10:45 PM
OriginalMadMax's Avatar
Re: Re: Re: learned something useful in chem class
They should teach this to tow truck drivers, cause they always just clamp onto the batteries!
Old Mar 15, 2002 | 10:46 PM
StrongIsleMax's Avatar
I remember in my uncle's old Hyundai Excel 4-speed, I would help him push start it because the battery would always die. Is this possible with newer manual tranny Maxima's? ...just in case my battery ever dies.
Old Mar 15, 2002 | 11:53 PM
global_threat's Avatar
HA, if ya'll would stop being "men" and just read the directions, they say exactly that
Old Mar 15, 2002 | 11:57 PM
jiaxima96's Avatar
My belief is that as long as the last connection is NOT on battery negative terminal BUT on some metal part away from battery, it should be fine. That is, you can connect jump cable onto both bad battery's terminals first. Remember that only the last connection will make the circuit complete therefore the last contact will have some spark to cause potential explosion. It doesn't matter which battery to connect first.
Old Mar 16, 2002 | 07:28 AM
2DMax's Avatar
Did this on my old Sentra, but that had a carb.
Don't know if you can do this with the new fuel inj. engines, anyone?
Old Mar 16, 2002 | 07:43 AM
Gotrice4's Avatar
isn't it possible that you can create an arc and short circuit all you electronics doing it the "correct" way? I've always jumped started cars using the "incorrect" way...
Old Mar 16, 2002 | 07:47 AM
bullseye's Avatar
Yes, you can push start a Maxima. My starter died on me last year. Lucky for me, I was parked on an incline, facing uphill. I put the car in reverse, turned the ignition switch to the ON position, let off the brake, and started rolling backwards. When I had a little momentum going, I quickly released the clutch. The car came to life immediately. I did not touch the gas pedal until the car started...
You can't do that on an automagic.
Old Mar 16, 2002 | 09:42 AM
it's not recommended.
Old Mar 16, 2002 | 10:10 AM
Newman's Avatar
i tried to do it the "right" way the first time i ever tried to jump a car and it didnt work. so i just connected both terminals of both cars and it worked. so now i just do it the wrong way everytime.
Old Mar 16, 2002 | 10:16 AM
97BlackMax's Avatar
...i've never had to jump my own car yet (*knock on wood*)...but i've jumped a couple of my friends cars, and the "right way" has never failed me...this is how i do it:
1-connect positive clamp to good battery's positive terminal
2-connect other positive clamp to bad battery's positive terminal
3-connect negative clamp to good battery's negative terminal
4-clamp other negative clamp to metal piece on car of dead battery to ground
never failed me yet
Old Mar 16, 2002 | 10:00 PM
White96MaxSE's Avatar
If I'm not mistaken the reason you connect the ground cable to a location other than the dead batteries negative terminal is to avoid creating a spark immediately overtop the battery that could cause an explosion.
White96MaxSE
litch
123
Jan 4, 2024 07:01 PM
REDinLV
Sep 28, 2015 12:31 AM
Tmax78
Sep 25, 2015 09:07 PM
keensali
Sep 23, 2015 08:59 PM
carid
Sep 9, 2015 05:06 AM
