my headlight died, its the connecter I think, can't fix it... help!
Old Mar 18, 2002 | 07:30 PM
costcowholesale's Avatar
my drivers side headlight won't work anymore. I brought another phlilps bluevision to try it on didn't work, tried stock didn't work. I talked to a few guys & they said its the headlight plug, they said its fried because I have aftermarket bulbs in them. So I brought another one from nissan today, cut the old one out, put the new one back in wtih wires connector
this is the old plug I cutted out
http://imagep.webphotos.iwon.com//10...M0.4081995.jpg
my new plug with wires connector connected to the wires that runs to the car
http://imagep.webphotos.iwon.com//10...M0.1354595.jpg
& it still won't work... whats the problem? Nissan gave me some **** wires connecter when I brought the plug & I tried to put those crap connectors on for two hrs & it didn't work so I went out & brought those orange connectors myself....
do I need a new harness? whats that? (...ok I'll go searching now )
Old Mar 18, 2002 | 07:36 PM
patel_anu's Avatar
when my headlight went out, all i did was go to autozone and buy a new 9004 socket for 4 bucks and just connected the wires and worked fine, hope that helps
anu
Old Mar 18, 2002 | 07:43 PM
anu
thats what I just did right? did I wire it wrong or something?
Old Mar 18, 2002 | 07:51 PM
patel_anu's Avatar
yeahh my bad, yeahhh check your wires and see if there connected right, but other than that, maybe your fuse might have blown out, so you might wanna check that out too, hope that helps
anu
Old Mar 18, 2002 | 07:54 PM
anu
sorry abt this dumbass question but how do u check fuse.... when it says left headlight does it mean driver's side headlight or passanger side headlight?
Old Mar 18, 2002 | 07:58 PM
patel_anu's Avatar
good question ....but i think it might be the drivers side, but check both fuses anyways. To check the fuse, just pop out the fuse and put it against a light or something and you'll know if its blown, it'll be black in the middle.
Old Mar 18, 2002 | 08:21 PM
problem fixed!!!!!!!!!!!! I think it was the connector, but then the fuse blew up because I think what happened was when I was putting the new socket on those three wires touched each other & blew themself up.
makes sense? is there any spare fuse in the car?
update** now both llights work, but only low beam works for both light, when I turn highbeam on only one bulb works, whatgives?
Old Mar 18, 2002 | 08:55 PM
patel_anu's Avatar
you might have some spare fuses in the fuse box but don't know for sure, you should be able to get them pretty much anywhere.
about the low beam problem, well it might be that you switched up the 3 wires or it could be the bulb itself, hope you get it working
anu
AaronL
Nov 15, 2020 11:52 AM
dcam0326
Sep 18, 2015 04:52 PM
Hdnseek
Sep 9, 2015 05:55 AM
Colossus
Sep 9, 2015 05:46 AM
