2002 Stang GT 5spd vs. 1995 Maxima 5spd SE
Old Mar 21, 2002 | 04:17 PM
Craig Mack's Avatar
All YOUR grammer belong to me
My neighbor just got a brand new Mustang GT convertable 5-speed manual.
I am going to convert to 5speed sometime in april, and would like to know my chances against him.
I have a WSP Y, Cattman CAI, 2.5" b (no resonator), flowmaster duals, 17x8 wheels...and when I get my 5spd I'm gonna put in a STS.
What are my chances in straight line acceleration up to say 60 or 70? He is completely stock.
Old Mar 21, 2002 | 04:23 PM
Craig Mack's Avatar
He's gonna eat me up isn't he
Old Mar 21, 2002 | 04:26 PM
Conrad283's Avatar
I need a truck
that stang has 260 hp and weighs in at 3300 pounds .. if he knows how to drive stick i'm pretty sure you're going to lose
Old Mar 21, 2002 | 04:30 PM
Craig Mack's Avatar
That's it? Just 260? I am probubly putting out about 220-233hp at the crank and weigh in at about 3,000 lbs.
Motor Trend claimed 5.4 0-60 and 14 flat in the quarter mile...those numbers don't really make sense for a car that is 260HP + 3300 pounds, do they?
But then again it has like 300pound feet of torque...but I heard American cars generally have weaker engineering so the power to the wheels has a greater loss than on some imports. Also his RWD losses more power than my FWD...
Old Mar 21, 2002 | 04:33 PM
MONTE 01&97 SE's Avatar
The May 2001 issue of Car and driver got a Convertible GT to 60 in 6.0 sec,1/4 mile was 14.7 @96mph. So you might have a chance.
Old Mar 21, 2002 | 04:50 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
convertible makes the GT a little heavier, but I still don't see an automagic 4th gen beating one!
Old Mar 21, 2002 | 05:02 PM
DA-MAX's Avatar
Originally posted by yo_its_ok
rice "wine"
I'll have mine shaken not stirred.....
Old Mar 21, 2002 | 05:36 PM
Craig Mack's Avatar
I won't be auto-tragic for much longer at all
Old Mar 21, 2002 | 05:55 PM
Badaxxima's Avatar
Look in any Hot Rod where they've dynoed a 4.6L 'Stang, they only have about a 15% driveline loss. Remember, driveline loss is about how well the drivetrain is engineered. Tremec made the transmission, the driveshaft takes a few, but it's still only 15% or so. A FWD only has less driveline loss due to the driveshaft and axlehousing, assuming similar engineering in the drivetrain. But this is Nissan, not the best for trannies, we all know the WONDERFUL job they did with their autotragics. The race will be close, but the Mustang has a LOT more power. 302lb-ft peak torque, at 4600RPM, around 250lb-ft at the hp peak. The Max doesn't have nearly the torque curve. It'll be a good race since it's a convertible, but he'll take you.
*Edit* Assuming he knows how to drive */Edit*
Old Mar 21, 2002 | 06:02 PM
CHI99Limited's Avatar
I raced a brand new yellow GT a few months ago an he SMOKED me. We raced out of a light when we both hit 10mph or so we both nailed it an buythe time we hit 60 or so he had atleast 4 cars on me....this was with just an intake and he had a 5spd(nice chirp into 2nd sold me on this one).
Old Mar 21, 2002 | 08:08 PM
Nealoc187's Avatar
SLOW
You are going to get beat on. Depending on how well you can drive (and the same with him) it might not be that bad, but he has the faster car. They run low 14s with a decent driver and high 13s with a really awesome one.
Old Mar 21, 2002 | 08:14 PM
Dave B's Avatar
Not DAVEB the parts guy
You will probably loose simply because you won't be use to the 5 speed and you're 17s will slow you down somewhat. A 5 speed convertible is a mid 14-second car on average. I raced a 01 GT coupe (drag radials, exhaust) a few weekends ago. He ran a 14.3@99mph to my 14.6@98mph. I was pretty amazed he didn't pull on me at all after the first 100'. He stayed 2 cars ahead the whole way down the 1/4 mile. BTW, he was ****ed when he found out I was just a V6 grocery getter. He did end up running a 14.0@100mph.
Dave
Old Mar 21, 2002 | 08:26 PM
Craig Mack's Avatar
Dave
Your right about that Dave. I would probubly bog the clutch and stall out...the max would be jigglin' like I had hydrolics i'd stall so bad
Well he just seems like a hotshot with a "stang ownz all" attitude and I would REALLY like to surprise him.
But I'm sayin' after I got used to the 5-speed, several months...he'd be the type of guy who'd smoke the tires off the line to show his "power" so i'd probubly get him there.
Dave, my 17's only weigh 19.9 pounds each, 39-42lbs. with tires (can't remember exactly)...I am sure those GT alloy's arent the lightest things.
I was gonna PM you Dave, but I'll ask here. If you have a 19 pound 17 inch rim and a 19 pound 18 inch rim, would the advantage go to the 17? I thought so becuase of rotational mass not only weight but some members here don't seem to think so.
Also you mentioned I would probubly lose do to my rims...do the rims REALLY make that much of a difference?? I know I couldn't feel the slightest lag after I switched from the stock 15" alloys to my 17s..
Old Mar 21, 2002 | 08:34 PM
02damax's Avatar
personally, i think he would have you for lunch.
just an opinion, though. i raced my friends 00 GT auto in my sho. he trounces me, and i do know how to drive. stock for stock, shos and maximas are close, i think. never raced one, though.
Old Mar 21, 2002 | 08:55 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
The first week I had my Max I stayed even with an older pre-99 GT on a local highway
But yeah, the 99+ GT's are a lot quicker. However, more than a few Mustang drivers think they're the shiznits and can't drive worth a crap. Who knows, you might be able to take him, or at least stay within a car of him and **** him off that a grocery getter was able to keep up. Just run him and find out!
Old Mar 21, 2002 | 09:23 PM
Dave B's Avatar
Craig-
If your rims weigh 19.9lbs, I'm almost certain your 17" tires weigh 23-26 lbs. Low profile tires are heavy because they have more steel belts and muc hthicker sidewalls. You're looking at a 43-46lb combo at the least. Does adding 6lbs to unsprung weight make that much of a difference? I think it does. I use to run 46lbs 17s. The best I ever ran on the 17s was a 15.0@92mph with a 2.25 60'. The I got light 16s (38lbs combo) and I ran a 14.7@94mph with a 2.26 60' with the same mods and under similiar conditions.
With equal weights, a 17" rim will be better than the 18" performance wise because more of the weight is centered around the hub instead of the outside of the rim (less rotationial inertia).
Dave
Old Mar 21, 2002 | 10:38 PM
RS Motorsports's Avatar
Hey dude how much are you payn for the 5-speed swap, cause I want to do this in the summer and want to get an idea of how much it costs. Also are you buyn your tranny new/used. let me know
Ryan
Old Mar 22, 2002 | 12:09 AM
BriGuyMax's Avatar
check this out.....
https://maxima.org/forums/showthread...hlight=Mustang
My thread from last June when I inched out a 99+ stang GT 5-speed.....I had only intake, y-pipe and A'PEXi cat-back.
Old Mar 22, 2002 | 01:12 AM
Nealoc187's Avatar
SLOW
Originally posted by BriGuyMax
check this out.....
Oh yeah? Which thread would that be chief? Haha
Old Mar 22, 2002 | 08:43 AM
MAX2000JP's Avatar
Your gonna get smoked. I test drove a 02' GT 5 speed 2 days ago and that thing moved pretty well. If the driver can drive it well, you will need to have NOS or a S/C to beat it from a standstill. From a roll things could be different.
Old Mar 22, 2002 | 08:56 AM
JAIMECBR900's Avatar
I haven't personally ran a newer GT but based on the numbers being stated here I would have to agree. N2O or S/C is going to be the equalizer in this equation. Just get the juice and smoke him...
Old Mar 22, 2002 | 09:51 AM
BriGuyMax's Avatar
ok...I was tired...it's there now....
Old Mar 22, 2002 | 09:57 AM
MAX2000JP's Avatar
Late night at your boyfriends house again???
Old Mar 22, 2002 | 10:05 AM
BriGuyMax's Avatar
you're just mad becuase you're 5th gen got SPANKED the other night on I-55...
I also heard you got beat by a Camaro V6 from an 80 roll......that sucks
Old Mar 22, 2002 | 10:13 AM
MAX2000JP's Avatar
BTW it was a LS1 Z28 with exhaust.
As for getting beat....My car is broken Wait till it gets fixed.
Done any off roading in your 4X4 lately? Hot Damn!
Old Mar 22, 2002 | 10:18 AM
BriGuyMax's Avatar
typical ricer excuses....
I heard you got pulled over for your winshield washer lights....that sucks
Old Mar 22, 2002 | 10:26 AM
MAX2000JP's Avatar
Nope..No LED lights on my car. Brian where did you get that lift kit for your Maxima? I didnt know they made them, is it a Custom Job?
BTW who is that flamboyant charachter in the reflection on your car? Is that your boyfriend? God am I bored at work right now.
Old Mar 22, 2002 | 10:43 AM
BriGuyMax's Avatar
dammit....you have way too much time on your hands.....hey are we partying at Anne's tonight???
Old Mar 22, 2002 | 01:34 PM
Nealoc187's Avatar
SLOW
Hey guess what boys, my hood shipped out yesterday. I should have it on by next weekend when I come out there. I beat the crap out of an IROC Z28 5spd last night too. That was fun.
Old Mar 22, 2002 | 01:43 PM
BriGuyMax's Avatar
You want a cookie?
Old Mar 22, 2002 | 01:49 PM
Nealoc187's Avatar
SLOW
You want a cookie?
Look Focker...
Old Mar 22, 2002 | 03:57 PM
BriGuyMax's Avatar
Look Focker...
Old Mar 23, 2002 | 12:28 AM
MAX2000JP's Avatar
My radioactive tailights are getting shipped, should be here anytime....
Old Mar 23, 2002 | 07:10 AM
sterling00max's Avatar
You are toast just waiting to pop out. "American weak engineering" equates to rattles and squeeks, but in the HP and torque department, Nissans don't have a chance. I'm not trying to ensight a flame war here, I'm just telling it like it is. I've owed 3 Maximas, and over 20 F-bodys. My 2000 SS will toast a Mustang all day, but the I wouldn't try one with my 00 Max. Go test drive a Mustang at a dealership. That will give you a feel for the car. I went to drive a 2002 Max, and was not impressed. The tranny is still a slip-o-matic. I just can't understand what they did to it in 2000. My 99 Max was a solid shifter. The 02's 255HP isn't supported by the torque, and comes on at highway speed. I'm holding out for the 03s..........
Old Mar 23, 2002 | 09:14 AM
BriGuyMax's Avatar
Do you realize we're talking about a modded 5-speed maxima here..NOT a stock 2000-2001auto...which has proved to be one of the slowest maximas EVER...probably becuase of the tranny.
Maybe something was wrong with the 2002 auto you drove becuase all the 2002 autos that have gone to the track are posting as good or BETTER times than an AUTO stang GT. The 6-speed maximas are posting times and traps similar to the 5-speed GTs....BONE STOCK.
The 02 isn't torquy?!?!?!?!?! WHAT????? You've got to be kidding me...obviously you don't know much about the 2k2 maxima's 3.5L VQ engine....the numbers from the factory are WAY off....when put on a dyno...the 2002 makes A LOT more torque than is advertised...that's why the autos are so much quicker than previous auto maximas.
Old Mar 23, 2002 | 01:20 PM
My 99GLE felt faster than the 2000, and the 2002 felt stronger than the 2000 in the top end. OK, so it dynos at more than the 246 advertised. Buy how much? 10-15.flbs? Whoopee.
It's still not in performance V8 territory. The stangs and the F-body shred tires because of torque. Big torque. I would invite you to drive one if you haven't. I have driven all of them. I love the 2000 Max for what it is, a great car with a crappy transmission and good family transportation. I just don't understand why people want to run them against v8 pony cars. If you want to beat Mustangs, buy a 99,000 mile Z28 for $3500, put $1000 in it in mods, and whip their pants off of everything but a Cobra. Just my 2 cents. Modding a Max looks like an expensive proposition to me.
Old Mar 23, 2002 | 01:41 PM
BriGuyMax's Avatar
Great...I'm glad they have torque...I drove a 2002 Stang GT 5-speed...and it was quick through first and second gear...but once it hit third it fell flat on it's face. Pretty Sad for how much power it has.
There are MANY reasons why I don't need or want an old Z28 to beat on Stangs. First of all...I need a reliable car with good build quality...not some 100,000 mile f-body that eats gas and oil like crazy. Second of all...when it snows in the winter here in chicago, I wouldn't be caught dead driving a RWD pony car. Third of all...I can beat up on 90% of all the Stangs in my area with my MAXIMA....when you pull up next to a stock stang in a Z28...they KNOW they are going to get whopped...and it's no fun...but when you pull up next to one in a family car...they think they will beat your pants off....and when they lose it's all worth it just to see the look on their face. In fact...I can beat up on stock LS-1s with my maxima as it is now...and that's even more fun....
BTW-The 1/4 mile time in my sig is from last year...my car is a good bit quicker now...plus I get almost 30mpg on the highway..and 21-22 mpg in the city...and I've put less than 2 grand in go fast mods into my car....there's my justification.
Old Mar 23, 2002 | 02:05 PM
SUPER-6's Avatar
As an outside observer, I got to say this is getting pretty close to a Civic board, where everyone can beat a Ferrari
Old Mar 23, 2002 | 05:13 PM
BriGuyMax's Avatar
Who ever said they could beat a Ferrari?????
I only stated what cars I can beat with my modded max...I didn't even name a single car that runs faster than low 13s in the 1/4. Is it so hard to believe that a car that is capable of runing 14.7 STOCK can run in the 13s pretty easily with juice??
If you think maxima.org is like a civic board.....get a clue.....and just take a look around....do you see one Ferrari kill??? Hell...do you see any Vette kills????
That's what I thought
Old Mar 23, 2002 | 05:36 PM
DA-MAX's Avatar
I know someone on here who could...
