How to prevent static shocks?
With winter coming on and the air getting so much drier, I'm finding that every time I exit my Max I get a wicked static shock. Anyone got any thoughts on how to limit this?
I was also pleased to find (as I scraped off ice from the car for the first time) that I have heated side mirrors.
- Andrew
- Andrew
The only way I've found that consistently works is to attach a couple of rubber straps to the rear axle that kind of drag/float above the ground while your driving. It's cheesy I know, but it keeps your car at close to the same potential as the ground, ie 0 volts. It's either that or a bunch of cans of static guard... which don't work well on leather.
What I do is carefully get out of my car without touching a metal surface. Then I touch the tip my key to the metal frame of the door, at which point I hear a static shock discharging. Then I shut the door with my hand. This technique does not always work, but it usually does.
My car has the worst static charge problems. I get blue luminous arcs jumping from my key to metal surfaces like the door or ignition cylinder. CRAZY!! One time, an arc jumped from my car to the gas pump nozzle!! I almost had a heart attack!!! Lucky for me...liquid gas isn't that flammable (it's the gas vapors that ignite, even in your engine).
Hence...the inventive signature title.
It's strange how all you guys get electicutad,
all the time my max has never sparked me I wonder why some people get sparked and others don't? Maybe you guys are just electric or something what do eat or drink? haha
Originally posted by Y2KevSE
Use your key and touch a metal part on your car.
Just go get an Earth Strip or an Earth antenna. And for those antennas, some of them look like that Ooglie Antenna on Kev's car.
Hey Eric L,
Nice sig caption!!!
Nice sig caption!!!
I have never gotten shocked from being in a car. I don't understand that. In fact, tire makers still use rubber in the compounds for this very reason. There is a large silica content in tires. Silica is actually a stronger and stickier material than rubber, but all-silica tires created terrible static electricity in the car during testing, so they went back to a design that incorporated circumferential bands of rubber around the tire to always keep the car grounded. So I didn't think anybody ever got shocked when getting out of a car. I'm glad I don't.
try this
..stop wearing nylon pants...get a good pair of Levi's............. on a more serious note..it only ever happens to me when I'm wearing running shoes in the car...It's WEIRD..any other kind of shoe, (mostly DOCS)..actually ALL DOCS....it never happens. Put on the runners>>>> ZAPPED
before you get out, put your hand on a piece of metal. door, roof, pillar, and then put your feet down. now stand up and close the door. i used to have that nasty problem with my 93 SR5 Toyota 4x4. happend to my mom once while she was carrying a bag of groceries... it wasn't pretty.
I think it's the shoes...
Whenever I wear running shoes, I get zapped...but if I'm wearing my leather soled dress shoes (like during work usually) no problem at all. SOmehting about how it grounds you. Also, if I wear my long coat (wool/cashmere) it gets a LOT worse.
my 2c.
my 2c.
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
