Where do I tap into power for my new heated seats?
Old Mar 26, 2002 | 01:06 PM
JJW95SC's Avatar
My car did not come with heated seats but I bought the elements when I bought my new leather seatcovers (see my other post in this forum).
The elements (one for each seat) came with the switches and power line but I'm not sure where to tap into the car for power.
Has anyone done this recently? I'm having a friend help me with it so I don't cook myself but we could use some pointers.
Jim
Old Mar 26, 2002 | 01:23 PM
1MAX2NV's Avatar
Re: Where do I tap into power for my new heated seats?
The correct way is to get it from the fuse block under the dash. There is probably a slot for the heated seats. Just plug in the fuse and get to the wires behind it. The easier way is to get the power directly from the battery and use the ignition switch as a signal to a relay.
Jim
Old Mar 26, 2002 | 05:39 PM
Synki's Avatar
Re: Re: Where do I tap into power for my new heated seats?
Couldnt he just use the ignition wire itself? Im not sure on how much power the heated seats draw but im assuming if its not that much, it can be done. If you can go this route, dont forget a inline fuse.
Old Mar 26, 2002 | 06:00 PM
1MAX2NV's Avatar
Re: Re: Re: Where do I tap into power for my new heated seats?
I think the current draw is too much for the ignition switch. If the draw is anything like nitrous bottle heater....that thing draws 30amps.
Old Mar 26, 2002 | 06:12 PM
JJW95SC's Avatar
Perhaps someone with stock heated seats can comment on how/where they're connected?
Jim
Old Mar 26, 2002 | 06:53 PM
ny96max's Avatar
Run a 10gauge power wire direct off your battery with an inline fuse for protection. Then use a relay and igniton wire direct from the steering column.
Ant
captchaos
Mar 15, 2016 12:18 PM
blakkheartt12
Sep 17, 2015 08:11 AM
tardrex
Sep 11, 2015 07:35 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
sdotcarter
Sep 2, 2015 09:53 PM
