300ZX Calipers with 12.5" 3000GT Rotors
Old Mar 27, 2002 | 11:37 AM
mxm_2k's Avatar
A little while back, Ginn Motorsports posted a thread on the Parts For Sale forum advertising a 12.5" rotor upgrade for those with the 300ZX calipers. Since I occasionally track the car, and was in the market for a big brake upgrade, I volunteered to be the guinea pig.
The brake kit fit without a hitch, the only modifications necessary being a different caliper bolt and shaving 3mm from the radius of the rotor. Wheel spacers were not necessary for my application, though they in all likelihood will be for most others. Surprisingly enough, the control arms did not have to be grinded down, which is a common 5th Gen solution to prevent rotor contact while turning.
Total parts came out to roughly $700 shipped to my door. This includes everything sans the steel braided brake lines, which I already possessed.
As for performance, initial impressions are that they are definitely superior to the stock braking system. Initial bite, overall distance, and resistance to fade have all improved noticeably. The only downside is the increased pedal travel, which is common to big brake upgrades. However, in my opinion, this is actually preferred, as it allows for additional feel.
I'll be posting a more detailed follow up after the 18th of April, during which I'll be visiting Willow Springs. At that time, I'll have a more accurate measurement of braking performance, as I've been there several times with the stock braking system, and have a relatively good idea of the prior braking points used.
If anyone is willing to post a few pictures for me, I'll go ahead and e-mail them over.
Old Mar 27, 2002 | 11:43 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
Re: 300ZX Calipers with 12.5" 3000GT Rotors
what needs to be done if you already have the 300ZX brake upgrade? the 3000GT rotors and a brake caliper bracket? how much would it cost? lemme know cause i would be interested..thanks
Old Mar 27, 2002 | 12:12 PM
SuDZ's Avatar
Was this on a 4th gen you did this or a 5th? Send me the pictures and I will host them for you. SuDZ@tromastyle.com
SuDZ
Old Mar 27, 2002 | 12:38 PM
Chunger's Avatar
My other car is a Hybrid
Pictures of the brakes...
stock #1
stock #2
big brake #1
big brake #2
Old Mar 27, 2002 | 12:47 PM
SuDZ's Avatar
Here they are
Stock1
Stock 2
Big Brake Kit
Big Brake Kit 2
SuDZ
Old Mar 27, 2002 | 12:54 PM
Chunger's Avatar
Lol....
Lol....
having a choice IS GOOD!
Old Mar 27, 2002 | 01:16 PM
SuDZ's Avatar
Originally posted by Chunger
Lol....
Lol....
I did not realize he sent them to both us us hehe. I did not refresh this post until after he sent it to me and then I put it up. Do you have any bandwith issues that you can max out? Just curious cause if so then having two will be good if they cut you off.
SuDZ
Old Mar 27, 2002 | 01:19 PM
Colonel's Avatar
Old Fuddy Duddy
Soooo
Is this a complete kit or do I have to hunt down the calipers myself? Can someone elaborate what is included and what I will have to get myself?
Thanks!
Old Mar 27, 2002 | 01:28 PM
Chunger's Avatar
Re: Soooo
Thanks!
old post
SuDZ ... we can keep them both up... I've got plenty webspace available. It's all good.
Old Mar 27, 2002 | 01:35 PM
Chunger's Avatar
Some info from an installation on a 300Z
http://www.binaryvista.com/ZCars/Z32/2002/01/index.html
Old Mar 27, 2002 | 02:04 PM
Chen127's Avatar
Hey TurboMax, I have a set of front rotors from a 93' 3000GT VR4 in good condiition. They sure as hell don't look like what is on that 5th generation max though. They look almost like cross-drilled rotors, but they are drilled all the way through, looks like just drilled indents into the rotor. Either way I'll sell you my rotors if you're interested. I'm in PA.
Old Mar 27, 2002 | 02:45 PM
mxm_2k's Avatar
Turbo95Max: Matthel, all that you would need to purchase are the brackets and the rotors. The installation is fairly straightforward. Regarding cost, I'll let Ginn answer that question since I am not certain if he has set a definite price for the Maxima community.
SuDZ: 5th Gen, though you probably know that by now.
Chunger & SuDZ: Thank you both for hosting the pictures. Lol, I did not realize that you would post them at the same time. My error, since I was worried Chunger had bandwidth issues from his e-mail response.
Colonel: The kit comes with the brackets, rotors, and brake pads. If you prefer, each piece can be ordered individually, if you already have the rotors and/or brake pads.
Chen127: Correct, they are dimpled rotors. The kit originally comes with cross-drilled/slotted rotors, but I had worries that they would be more prone to cracking. As such, I substituted the rotors for these alternate versions. I'd have preferred slotted, but those are the only two options he carries.
Old Mar 27, 2002 | 04:30 PM
GinnMotorsports's Avatar
I will sell the kit for $450 + shipping.
It includes:
All hardware
2 dimpled and/or slotted rotors
Front Metal masters pads
What else do you need?
2 front 300zx calipers from a 90-96 300zxTT or from a 91-96 Non-turbo. These are 30mm calipers, the calipers from a 90 non-turbo are not as wide and WILL NOT FIT. Iron or aluminum is your decision, they both work.
I get my used parts from zxparts@mindspring.com, tell Russel that chip @ ginnmotorsports sent you.[IMG] http://ginnmotorsports.com/images/12.5_brake_kit.JPG[/IMG]
Old Mar 27, 2002 | 08:04 PM
xHypex's Avatar
Sounds like a nice setup. I'd be interested to see how this compares to the big brake kits since the price is definitely right. Too bad I already did my brake upgrade for a while :P
-hype
Old Mar 28, 2002 | 12:00 AM
Turbo95Max's Avatar
thanks for the reply guys
couple more questions
Can i order juss the hardware and brackets? i can get rotors and pads on my own. Will these fit 4th gen? i think the pics were on a 5th gen and i know 4th and 5th gen have different size caliper bolts. if you would sell me juss hardware and brackets i would be interested in picking up 2-4 sets. Thank you. Very interested!
Old Mar 28, 2002 | 10:42 AM
psu max's Avatar
on a side note, it looks like the 3000gt rotors just barely fit under non turbo Z rims .
so wat are the odds that this kit, adapted to the max, will fit on a 4th gen under na Z rims ??? i'm betting none, i hope im wrong tho. any other opinions???
edit: n/m ... they fit under Z rims w/ 15mm spacers ... there goes that idea
Old Mar 28, 2002 | 11:16 AM
Erock's Avatar
Just what the doctor ordered
Maybe I misunderstood something... the only reason we need these brackets is to fix the caliper offset for the new rotors? If we use the smaller 300ZX rotors there is no need to buy the brakets at all? Do the slightly bigger 3000GT rotors make that big of a difference? Lastly, these brackets can be used on both 4th and 5th gen maximas to attach the Z calipers to the 3000GT rotors? Will the adaptors work if we want to upgrade to the Skyline Calipers? If so I am ready to buy!!
Old Mar 28, 2002 | 01:08 PM
Turbo95Max's Avatar
Re: Just what the doctor ordered
well, Skyline calipers are almost the same as Z calipers and they bolt on to the Z so it should work. I guess the 3000GT rotrs are 12.5" and the Z ones should be about 10.9 or was it 10.1? cant rmeember. i juss want to know for sure it will fit on 4th and 5th gens cause like i said earlier the caliper bolts on 4th and 5th gens are different. one is 17mm one is 19mm.
Old Mar 28, 2002 | 01:22 PM
avusblue92se's Avatar
psu max
you would have to put on 5mm spacers on the front wheels anyway to make the z rims fit, so maybe 15mm woulnd't be to much different. i am not sure but it may work, and it woudl be a lot cheaper than a skyline or wildwood upgrade.
Old Mar 28, 2002 | 01:29 PM
Erock's Avatar
Clarifying...
I am assumming that the only reason that we would need these new brackets would be if we are going to use the 3000GT rotors? Is this correct? The reason that I ask is because I have always heard that the 300ZX Calipers will bolt onto a 4th gen with no adjustment to the brakets. You just have to shave the rotors a bit.
Old Mar 28, 2002 | 02:51 PM
My hardware is ONLY for use with 94+ VR4 rotors, I do not know anything about skyline application on a Maxima, they bolt directly onto the 300zx.
Old Mar 29, 2002 | 08:30 AM
Erock's Avatar
Further...
So your brackets will fit the 4th gen Maxima?!
Old Mar 29, 2002 | 11:02 PM
Re: Further...
They will fit 4th or 5th gen, but the bolts to mount the caliper is different. You need the bolts from the 300zx, in other words the bolts that originally attached to the 300zx calipers.
Old Mar 30, 2002 | 06:32 AM
DanNY's Avatar
Ad·min·is·tra·tor
How are these calipers going to connect to the stock brake lines? Does your kit include the brake line also? The stock maxima caliper is a banjo bolt set up, on the 300ZX caliper it's a male/female threaded set up.
Old Mar 30, 2002 | 06:54 AM
You will need the existing 300zx setup: calipers and lines. Whatever lines you are using for the 300zx calipers.
This was designed to work on a 300zx, I am not familiar with the Maxima brake line setup,but whatever you guys have been doing to use stock 300zx brakes is what you need.
Old Apr 1, 2002 | 10:13 AM
Erock's Avatar
few more...
Are the rotors that you sell already trimmed to the correct overall diameter that we need, that is I am assuming 12.5 inches??? Also, is there anyway to order them truly crossdrilled? If not, is there someone who can crossdrill them for me? I am ready to order the brackets, but would like to be able to talk to someone first.
Old Apr 1, 2002 | 10:44 AM
My rotors are not sized correctly for the Maxima, I am working with my supplier on having them trimmed. My supplier does not drill anymore, I weakens the rotor, since the holes are not cast into the rotor, but drilled.
Call me and leave a message.
334-826-0939
Old Apr 1, 2002 | 02:09 PM
SuDZ's Avatar
Hmm, if this could be a bolt on kit it could be nice. I was thinking that I need brakes soon.
SuDZ
Old Apr 1, 2002 | 02:41 PM
Shadow's Avatar
You should be able to use the stock brake lines. When I did my conversion 2 years ago, I got SS lines for a Maxima, and when we test fit, it works perfectly. Then I had a line blow out, and it was temporarily replaced with a stock Maxima brake line which worked perfectly also.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
