AGX adjustments - do I need to lift the vehicle
I had my agx's installed yesterday and i want to play with the settings. I haven't had any time yet to do this, but it looks like
i need to jack the car up to reach the dials.
I have eibachs on too.
thanks
Greg
thanks
Greg
The fronts are adjusted by the little screw on top of the piston. The screwdriver should have been provided by KYB. Remember to push down before you turn the screw.
The rears are a dial which, depending on which way there facing can be reached from around the wheel. I put my dials facing inward and I can reach them easily to make adjustments. You just have to remember which way your turning. Righty tighty, lefty loosey. And don't lose track of what setting your on. If you do, then crawl under the car and look at each shock. Always makes sure there both set the same.
While we're on the subject does anyone know how the adjustment on the AGXs work? I'm always afraid I'm going to click over 1 extra click from 8->1 and screw something up. So whenever I adjust my shocks I make sure I look at the numbers. I looked at KYBs website on adjustment and they don't even have a FAQ or anything that mentions what you should do or how the adjustment works
-hype
-hype
Originally posted by brodaiga
they sent me instructions with my shocks on how to do it, i wish I had a working scanner to do it for you, did you get those? if not, give your address and I'll send you one by mail.
-hype
litch
123
01-04-2024 07:01 PM
tarun900
19
12-20-2021 06:57 PM
maxima-junky
10-07-2015 06:13 PM
