Throttle jammed! Warning!
Old Mar 29, 2002 | 08:42 AM
OriginalMadMax's Avatar
I was getting on the freeway last night and a couple of Hondas looked like they wanted to cut me off, so I played with them making the left and then floored it on the onramp. Bye bye! But ... my throttle felt weird, like it had 2 stages, so I played with it and there was a definite hitch I could feel with my foot; not good! I got off at the next exit to pull into a gas station and the engine seemed to slow less quickly. When I popped the hood I was surprised to see the hose clamp on the throttle body, which was still tight, had somehow rotated so that the threaded barrel was interfering with the movement of my throttle! An easy fix, but potentially very dangerous. If the clamp had rotated any further, the throttle spring might not have been strong enough to return. Check yours!
Old Mar 29, 2002 | 10:19 AM
BSwithTF's Avatar
I had the same problem.
I left my house one day and my throttle would only go down halfway. Now matter what I did, I could only get the car up to about 2000 RPM's. So I pop the hood and same thing. My clamp had come a little loose and got in the way of the throttle. Moved it, tightened it, and I was on my way. I can see the danger though if the throttle had made it's way past the clamp and then got stuck at full throttle or something. That could get a little hairy. My sister had her throttle stick wide open on her Trans-Am GTA one time. I think she panicked and ended up throwing it into park at 80mph!! Ouch.
Old Mar 29, 2002 | 01:00 PM
NotNew!!NewSN!!'s Avatar
Re: I had the same problem.
that happend from my cold air intake, i posted sompin about it a while ago under madmax26 i think. make sure to check it when u put in the foam connectors
Old Mar 29, 2002 | 02:44 PM
emax02's Avatar
Re: Throttle jammed! Warning!
When I took my SC of my old I30 and put everything back on the car I had the same problem. MY I30 sat for a few days during the SC removal and when I started the car up it and gave it a little gas the tac just bounced off of redline It freaked me out, luckly I figured out the problem quickly!
litch
123
Jan 4, 2024 07:01 PM
msellas
Sep 23, 2015 09:16 PM
bumpypickle
Sep 20, 2015 08:22 AM
Bonka
Sep 14, 2015 11:18 PM
lowpost99
Sep 8, 2015 05:06 AM
