I'm going to remove my Cattman Y-pipe
I'm going to remove my cattman y-pipe to see if I have the flex failure. My question is, will I need new gasket if I wanted to put my stock pipe on. Is the gasket reusable?
Re: I'm going to remove my Cattman Y-pipe
Re: Re: I'm going to remove my Cattman Y-pipe
Originally posted by MAXINXS
The gasket that goes between the y-pipe and the cat can be reused if it's still in good shape. But the two gaskets that seal the connection to the exhaust manifold you will have to replace. They are crush rings and can only be used once to form a tight fit.
Originally posted by Nismo
wouldnt it be more easier to just remove the cat and look through the flex from there? maybe use a mirror with a flashlight
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
