UDP harmful???
Old Apr 4, 2002 | 04:36 PM
poorcollegeboy's Avatar
UDP harmful???
i know i have been pretty negative with mods lately but....
the stock crankshaft pulley has a harmonic balancer which prevents the crankshaft from cracking or oil pump from breaking at certain rpms/frequencies.
where are the harmonic balancers on the udps???
although the only known incidences of this happening are on honduhs and mazdas.... it's something that could/should be looked into.
has anybody noticed any extra vibrations when slamming on the pedal?
Old Apr 4, 2002 | 04:55 PM
Jime's Avatar
there is no harmonic balancer on a VQ Maxima crankshaft pulley you have a balanced engine confused with a Honda
Old Apr 4, 2002 | 07:00 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I could've sworn the VG Maimxas had a harmonic balancer...
Originally posted by Jime
there is no harmonic balancer on a Maxima crankshaft pulley you have a balanced engine confused with a Honda
Old Apr 4, 2002 | 07:42 PM
sleepermax's Avatar
Re: UDP harmful???
none whatsoever.
Old Apr 4, 2002 | 10:08 PM
Nismo87SE's Avatar
We have a harmonic dampner but not a balancer. A balancer would bolt onto the crank pulley and it is usually filled with fluid.
Old Apr 5, 2002 | 05:41 AM
Lime's Avatar
ARGH!
DO A SEARCH!!!!!!!!!!!!!
To REVAMP for the 30th time, the VQ is INTERNALLY BALANCED.
Morfeus17
Mar 31, 2001 02:21 PM
y2kse
Feb 25, 2001 08:47 PM
Andrew91SE
Nov 26, 2000 03:05 AM
ohboiya
Oct 9, 2000 12:23 PM
