Q: Ok to mix Dextron II & Dextron III ATF's(?)
This is for the power-steering reservoir - NOT for an automatic tranny.
My PS reservoir's a little low (right @ the MIN lines) - thinking about topping it off, but I think the old standard (Dex II) ATF is in there.
Is there any problem mixing in the new Dextron III type, or should I drain off the old fluid first?
TIA.
TIA.
Originally posted by Eric L.
Should be no problem. Most newer fluids are completely compatible with older fluids.
(I'm a belt AND suspenders kinda guy, no offense).
Originally posted by WizzaMax
Dexron III is a quality grade one level further than the Dexron II standard...III meets or exceeds all manufacturers recommendations for II lubricant.
As I understand so far, type II & III are fundamentally the same except maybe for a modified additive package in (III), ergo, it should be no problem to mix them.
Thanks, all.
litch
123
01-04-2024 07:01 PM
