Park lights went out
Old Apr 6, 2002 | 05:18 PM
SMX's Avatar
SMX
Installing my alarm, come to find out the brain is no good…. Now I having problems with the park light, they are not working, the headlights come on but that’s it. No tail lights, or park lights, and no dash lights. I found one blown fuse and replaced but its still isn’t working. When I put on the turn signal its works or step on the brake the taillights light up. But when I turn on the park lights I get nothing. Any thought on what its could
Old Apr 6, 2002 | 05:39 PM
Yellowbrother's Avatar
if i remember correctly...there is two fuses...one for brake lites and one is labeled hazard lights...and i also believe there is signal lights fuse also..check the cover out...
Old Apr 6, 2002 | 06:14 PM
SMX's Avatar
SMX
Ok . Checked the cover tested all the fuse in the fuse box under the dash. BAT 7.5A TAIL /BAT 7.5 INT ILL /ST 7.5 STARTSIG.All three in one line across has no power. What did I do?
Old Apr 7, 2002 | 12:40 AM
main fuse under the hood???
Old Apr 7, 2002 | 01:33 AM
magnum's Avatar
theres one fuse under the hood that controls the park lights, tail lights, and console lights... looking at the engine from in front of the car, its on the right side. dont remember what its labeled as tho. in any case, its in the engine bay. a simlpe 10 amp fuse.
Old Apr 7, 2002 | 03:47 AM
SMX's Avatar
SMX
There is no power in the switch in the steering column. There is supposed to be a constant 12V in the red and green wire but its dead. I run a wire from the Batt to that wire that should have been hot and the lights come on. So somewhere there is a broken link. i check the fuses under the hood. everything check out fine...but there is a broken link somewhere.
Old Apr 7, 2002 | 05:40 PM
SighMax's Avatar
Maxima Enthusiast
Re: Park lights went out
Chech the fuse for "Tail lights" in your fuse box where all your accessory fuses are inside cabin. The fuse is on the first column, 4 or 5th from the bottom. Should be a 7.5amp fuse.
Originally posted by SMX
Installing my alarm, come to find out the brain is no good? Now I having problems with the park light, they are not working, the headlights come on but that’s it. No tail lights, or park lights, and no dash lights. I found one blown fuse and replaced but its still isn’t working. When I put on the turn signal its works or step on the brake the taillights light up. But when I turn on the park lights I get nothing. Any thought on what its could
Old Apr 8, 2002 | 06:30 AM
SMX's Avatar
SMX
Checked it. there was on fuse blown (7.5) in the first row, I replaced it but still nothing. All other fuses where fine.
sctludwig
Sep 1, 2022 01:32 PM
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 6, 2015 10:42 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
